Very slow screen redraws
    ncafferkey
    Posts: 38 from 2006/1/6
    I recently installed MorphOS 2.2 on my Pegasos II, but I have a problem with graphics. Initially after booting, graphics are fast and smooth, but after a few seconds of activity screen redraws become extremely slow. I can watch each GUI element peel on and off the screen. Does anyone know what might be causing this? My graphics card is a Radeon 9200SE with 128MB, which works fine in MorphOS 1.4.
  • »04.01.09 - 21:06
    Piru
    Posts: 617 from 2003/2/24
    MorphOS 2.2 made the 3d acceleration default for Radeons. It seems it nukes on your Radeon for some reason (if this happens the system falls back to CPU, which will be really really slow, just as you descibe).
    You can disable the acceleration by using 2D boot option:
    boot ...whatever... 2d
    What version of the openfirmware do you have? If it's older than 1.1 you should upgrade. New firmware and install instructions:
    http://www.bplan-gmbh.de/output.php?PAGE_ID=162&LANG_ID=2&nid=16
    [EDIT]
    Sorry for the confusion... 1.1 not 1.2 :-)
    [/EDIT]
    [ Edited by Piru on 2009/1/5 1:51 ]
  • »04.01.09 - 21:16
    ncafferkey
    Thanks, that improved matters, but it didn't completely fix the problem unfortunately. Now, graphics stay fast for longer, maybe two or three minutes, but they eventually get slow again. Not quite as slow as previously though, presumably because the CPU now only has to emulate 2D acceleration instead of 3D. Is there a non-accelerated option?
  • »04.01.09 - 21:37
    Piru
    Check the openfirmware version (see the edited post from me), earlier than 1.1 had some gfxcard related issues.
  • »04.01.09 - 21:41
    ncafferkey
    Yes, I have SmartFirmware 1.2 (20040810112413) installed.
  • »04.01.09 - 21:53
    Piru
    Hmm, weird. That wouldn't happen to be a PCI Radeon would it?
  • »04.01.09 - 22:02
    ncafferkey
    No, it's a low-profile AGP card. This is an ODW box provided by Genesi, so there should be a good few other people with the same set-up. I'm therefore surprised that no one else has had similar problems. I did change the RAM recently, but I spent some time making sure that the system was still stable (in MOS 1.4). I presume if the RAM was the problem, it'd be more likely that the whole OS would fall over.
  • »04.01.09 - 22:12
    Piru
    Indeed, I'd think more people would have this problem.
    I'm at a loss here, but it sure does sound like the gfxcard falls over for some reason. I assume it works just fine for 3D under 1.4? No lockups or crashes after some time?
  • »04.01.09 - 22:26
    koan
    Posts: 303 from 2005/11/21
    I had a similar problem when I went to 2.1; similar set up to you. All screen updates were very slow. I did a fresh install and it solved the problem. Can't say I recommend this option though.
    I haven't installed 2.2 yet, so fingers crossed I won't have the same problem again.
  • »04.01.09 - 23:17
    Jupp3
    Posts: 1193 from 2003/2/24
    I had similar issue with radeon driver crashing earlier using older firmware. I got some messages concerning that in debug log, maybe you should check what it says?
  • »05.01.09 - 07:47
    Posts: 2090 from 2003/6/4
    I have with 2.1 and 3d enabled the prob, that after a while the screen goes blank (i.e. monitor turns off). System's still running, buf gfx is >NIL:
    My system is a Peg1 w/ Club 3D AGP-Radeon 9250/128MB, MorphOS 1.4.5 is running stable.
  • »05.01.09 - 13:23
    analogkid
    Posts: 719 from 2004/11/3
    I've got similar probs with my Radeon 9000. With the default Radeon driver from MorphOS 2.2, gfx refresh gets very slow, no matter if 3d layer is enabled or not. It really seems to be a OF issue. No problems with 1.4.5 though. My system is a Peg2 G3/600.
    [ Edited by analogkid on 2009/1/5 16:28 ]
  • »05.01.09 - 14:26
    ncafferkey
    What's the easiest way to check 3D under 1.4? Also, how do I access the debug log?
  • »06.01.09 - 00:08
