Peg1 graphics card for HDMI
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    Hi guys, I have a peg1 here with MorphOS2.x and voodoo3 graphics card. It is connected to a 720p HDTV with SVGA input, with a cybex keyboard/mouse/vga switcher.
    It works fine, but the voodoo was designed before HDTV standards were common.
    Can anyone recommend a graphics card for the peg1 that can output to an 720p HD LCD monitor with HDMI input? I'm sure the cheapest cards output DVI, which needs an adapter or a cable with DVI and HDMI connectors..
    [ Edited by Darth_X on 2008/12/22 13:35 ]
  • »22.12.08 - 20:32
    Simon
    Posts: 809 from 2008/7/6
    My radeon 9000pro and my 9200 has a DVI-output ... these are more or less the fastest cards you can get for MorphOS.
    But I doubt that you will get something to see on your tv when you connect it with a DVI-to-HD adapter unless your TV supports this.
  • »23.12.08 - 11:38
    Neko
    Posts: 301 from 2003/2/24
    They don't exist - no AGP card built for HDMI comes in voltage level that is compatible with the Pegasos I.
    Your best bet is to get a DVI to HDMI cable (which would not be more than $10 if you check Amazon or so. Do NOT go to Best Buy or any retail outlet, they will charge you a fortune) and a cheap Radeon 9250.
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »23.12.08 - 13:23
