black case for Efika.
    liquidbit
    Posts: 407 from 2003/10/12
    Guys,
    I found a great Lacie case to host the small Efika.
    http://www.lacie.com/us/products/product.htm?pid=11089
    I 'm waiting opinions ... 8-)
  • »26.11.08 - 10:30
    Nice, but I think a shiny black repaint of my Directron case would be a close imitation of that case.
    Edit: Okay, I should have wrote "the case I got with my EFIKA when I bought it from Directron". I have seen some nice cases where users have gutted other devices to put their EFIKA inside, but I wonder what they do with the guts of that device afterward? The nice thing about the case I have is it's small size. The only modification I did was to move the Blue led which shows that it is running from the back to the front at top center. Appropriate for a machine running MorphOS.
    [ Edited by amigadave on 2008/11/26 13:32 ]
  • »26.11.08 - 11:36
    Neko
    Posts: 301 from 2003/2/24
    Why would you buy a 500GB network appliance just to strip it and put an Efika in there?
    Dave is right, you could just respray your Open Client case (although wrong that it is a "Directron" case, it was actually designed by Dennis Clarke at Blastwave)
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »26.11.08 - 15:43
    Tcheko
    Posts: 539 from 2003/2/25
    Yay,
    With a nice LaCie logo on the side...
    The case is 117mm large which is the size of the Efika board as well. I think it won't fit the lacie case.
    Sad. The case looks pretty good.
    Czk.
  • »27.11.08 - 06:54
  • ZB
    ZB
    Posts: 115 from 2008/9/29
    Krashan wrote:
    Movie #2 on this page  :-D
    Speaking of those videos, the subtitles for the first one will still be released ?
    [ Edited by ZB on 2008/11/28 11:17 ]
    [ Edited by ZB on 2008/11/28 11:18 ]
    Morphing the Phoenix...
  • »28.11.08 - 08:16
    Drako^lM
    Posts: 144 from 2005/8/10
    Yes
    I plans to finish subtitles over the few days :) 8-)
    Hardware :
    Power Mac G5 2.3 Ghz & MorphOS 3.18 & OSX 10.5
    Mini G4 1.5 Ghz & MorphOS 3.18
    BlaBla Team Member -> http://blabla.ppa.pl
    AmiParty Team Member -> http://www.chal.pl/
  • »28.11.08 - 10:24
  • ZB
    ZB
    Ok, thanks.
  • »28.11.08 - 12:56
