Posts: 198 from 2008/7/10
Hi
Been meaning to post about this for a while. When I boot up (or reset) my Efika it will always boot up to the Firmware, but doesn't always boot into Morphos.
Sometimes it will not even get as far as the loading screen, other times it seems to hang on the loading screen. At first I thought this was a Morphos problem, but I'm starting to thing it's hardware related.
Is it possible the the harddrive doesn't spin up fast enough? When it does boot up all the way, the system is relatively (for Morphos 2.0 on Efika!!) relatively stable.
Thanks in advance
Zetec-s
