USB CD drive under MOS 2.0 / EFIKA
    motorollin
    Posts: 74 from 2006/8/30
    Is there anything I have to do to get a USB CD drive working under MOS 2.0? I have just bought one of these, but no CD drive icon shows up when I plug it in and put in a CD. It works under Windows (no driver required there). I haven't actually installed MOS, this is just from the installation image. Not sure whether that matters.
    moto
  • »26.07.08 - 10:36
    Cego
    Posts: 738 from 2006/5/27
    have a look at "mymorphos" drawer.
  • »26.07.08 - 10:43
    motorollin
    Cheers Cego. I did need to look in there after all. But there was another problem. It seems the IDE->USB adapter needs to be plugged in at boot in order for MOS to see it. I couldn't do this before since my USB memory stick used one port and my 2 port hub for keyboard and mouse used the other. After installing MOS on a CF card I had a free USB port. Plugging the IDE->USB adapter in to the other port before powering on works fine.
  • »26.07.08 - 15:57
    Posts: 646 from 2004/4/15
    I used a noname ide2usb adapter with a lg dvd-rom,
    no propblem here, ...
  • »27.07.08 - 03:59
    motorollin
    Did it matter whether yours was plugged in from boot or not?
  • »27.07.08 - 05:35
    Didn't test it,
    i plugged it in after booting and poseidon recognized it,
    and after could use it (installed wipeout this way].
  • »27.07.08 - 08:40
    motorollin
    Perhaps it didn't like being plugged in along with my USB memory stick, or instead of the keyboard or something. I haven't set up my EFIKA since installing MOS and getting the CD drive working so I can't re-test hot-plugging it, though I'm sure I tried this and it didn't work. I'll try it again the next time I set the machine up. Maybe it depends on the USB adapter!
  • »27.07.08 - 09:01
