PEG 1 & Wifi..Which hardware pci card?
    shakenfr
    Posts: 10 from 2007/12/29
    Is it possible to connect the PEG I using a wifi card ?
    If yes which wifi card is supported ?
    best
    Bruno
  • »22.01.08 - 05:02
  • Visitor
  • http://aminet.net/driver/net/prism2.lha
    download and look inside the manual.
    but there is the problem that you only have WEP encryption.
  • »22.01.08 - 05:39
    Posts: 1932 from 2003/10/19
    and its only B speed. Your best bet would be to just get a wireless ethernet bridge. You can then set it up through a browser and have real security and decent speeds.
  • »22.01.08 - 05:46
    shakenfr
    Thanks a lot for your quick answers
    best
    bruno
  • »22.01.08 - 06:11
    AyoS
    Posts: 410 from 2003/8/13
    I am thinking of adding a wireless network to my home. I currently have a Dell Inspiron 600m that will work purfectly... As for the PegII I am taking acill's advice and looking into a Wireless Ethernet bridge. Does anyone here have any experience with any particular models/manufacturers? I have looked at a linksys WAP54g... which Newegg has listed for $69.99... I have also seen cheaper brands... can anyone give me some advice as what to stay away from... currently I don't even have a Wireless router yet... so I could use some advise on that as well?
    Thanks in advance.
  • »19.07.08 - 02:32
