Posts: 2732 from 2003/2/24
Quote:jacadcaps wrote:
Anyone knows the minimum specs of GFX HW (like GPU, memory) to use the new 3D GUI functions in MorphOS 2.0?
256MB ram, G3 600 + an R200 based Radeon with at least 64MB ram is a minimum imo. G4 for full comfort. While it also works on Efika, it will generally be too slow for normal usage. Layers3d currently need a lot of ram (additionaly to graphic card's memory), so the 128MBs of the Efika aren't really enough.
Thanks for the info. Much appreciated!
Does the need for "normal" RAM decrease if GFX card RAM increase, and at the same pace (i.e. if 128MB is added on GFX side then 128MB less is required on the computer side)?
BTW, I understand the "the more the merrier" logic when it comes to specs. But still, I have also seen many of those online videos of Efika's using Layers3D, and while I understand your concern from *your* point of view (I understand your high standards and demands as a developer), I must say that I'm still very impressed of what I saw in those videos! Didn't look too shabby in my eyes, not at all, it looks very usable!
But OK, I don't have your reference points of using Layers3D on G3 and G4 Peg's. Of course everything is better there, it would be strange otherwise. It will be interesting to see with my own eyes how this works, and compare, since I have all the machines you mentioned!
I only hope that the licensing model is going to allow me to install MorphOS on at least 3 of my compatible machines I have here without taking out a second mortgage on the house...
BTW, do you have any ideas (theoretically) of how Layers3D would perform on a 5121e with its built in DIU and 3D GPU? I understand that it's a matter of RAM in this case as well, but just looking at the specs of the "PowerVR MBX Lite" - if enough amount of memory is present, wouldn't this core be enough?
While Layers3D isn't a *fundamental* thing to have, I think it's still a *very* cool feature, and I think it would be really cool if *all* aspects of MorphOS would at least have as a goal to be able to run at least adequately on these kind of low power SoC's. And BTW, 256MB? Any chance of working towards lowering that requirement? I mean, in one of my pegs, 256MB is all I got, and it would be nice to be able to use it for other things than the MorphOS GUI...
MorphOS is Amiga
done right!
MorphOS NG will be AROS
done right!
