2"1/2 HDs with 40 pins IDE cables...
    mahen
    Posts: 118 from 2003/2/24
    Hi everyone,
    I have a quite decent spare 2"1/2 harddrive I would like to use with a Pegasos 1. I was about to purchase a 2"1/2 -> 3"1/2 cable or adapter, but realized there were only 40 pins ones on the market. So I guess it won't work ? What do you think ?
    Here is an example of such an adapter
    Thanks for reading :)
    cheers,
    Mahen
    xmpp:mahen on jabber.fr
  • »02.07.08 - 08:53
    magnetic
    Posts: 2129 from 2003/3/1
    Well man its not 80 PINS its 80 WIRES. Its still 40 pin connector with an 80wire cable.. the extra 40 wires are GROUND (*earth in europe)
  • »02.07.08 - 08:57
    Posts: 1090 from 2004/9/23
    Those interfaces work well. I own one myself.
    Geit
  • »02.07.08 - 08:58
    mahen
    Well, that's what I meant, I chose the wrong word :)
    Well, even the MOS team makes this mistake ;)
    A: Always use 80 pin IDE cables for everything. 40 pin cables are not supported.
    Edit : Geit : cool, thanks !
    [ Edited by mahen on 2008/7/2 11:59 ]
  • »02.07.08 - 08:58
