RAM for Pegasos II
    serge
    Posts: 725 from 2003/2/20
    I have to choose a 2 GO ram set for my pegasos II.
    I have two solutions
    First - two modules of 1GO
    Second - one module of 2GO witch is very very expensive.
    My question is: Does Pegasos II work fine with Two ram modules?
    Thx.
    [ Edited by Genesi on 2008/6/24 23:53 ]
  • »23.06.08 - 06:50
    ironfist
    Posts: 254 from 2004/4/22
    You should probably stick to two gigabyte-modules.
    I don't think MorphOS will handle 2 GB, but Linux
    should have no problems.
  • »23.06.08 - 12:25
    Daff
    Posts: 247 from 2003/4/5
    If you have actually 256 or 512 MB on your Pegasos, you can buy 1x1 GB, it's very nice on MorphOS.
    If you have already 1 GB on your Pegasos, a 2 GB module is very expensive and not very useful (only 1.5x GB will be active and no MorphOS software use such among of RAM).
    BTW, 2x1 GB don't work for many users. Personaly, I can't plug my 1 GB module with my other 512 Mo module on the Pegasos.
    http://obligement.free.fr
  • »23.06.08 - 18:08
    SoundSquare
    Posts: 1214 from 2004/12/1
    from my experience, using 2X1Go on my Peg2 was pretty useless unfortunately. I used 2 ram modules that were strictly identical, MorphOS could use only 1,5Go (which is too much anyway ! there's no use for such an amount of ram in MOS, which is a good thing) but on linux (Gentoo and Debian) i was having some compilation errors. Removing one of the sticks (one or another) solved the compilation issues. no more errors.
    Just my 2 cents.
    [ Edited by SoundSquare on 2008/6/23 22:08 ]
  • »23.06.08 - 19:07
    serge
    Hi guys,
    I'm recording all weeks a radio program about UFOs  :-)
    I'm doing sometimes 4 or 5 hours of streaming mp3 records with AminetRadio.
    I do this records all by night when I'm sleeping.
    Then, I have to edit the records to clean them.
    When I load a 2 hours MP3 on PSA with 1GB, The ram goes to 100% full with 90% MP3 loaded.
    So, I need more ram to load my very big files.
    I would be nice to have some virtual memory like VMM on classic.
    I'll buy 2 X 1GB whishing they work fine together on my peg.
    [ Edited by serge on 2008/6/23 22:36 ]
  • »23.06.08 - 19:33
    BatteMan
    Posts: 290 from 2003/2/24
    Serge : Make a new project in PSA and use your HD for it instead of ram. It will work (I hope ;-) ).
  • »24.06.08 - 14:59
    Posts: 1084 from 2003/3/24
    Or try "smart saving" with anr then you get a few mp3 files without the jingels and music inbetween.
  • »24.06.08 - 15:48
    serge
    you are write ! very cool.
    thank you very much
  • »25.06.08 - 07:30
    CountRaven
    Posts: 566 from 2007/12/10
    Sorry for the off topic but is it a way to stream mp3 on AminetRaido and then broadcast em to people? -somehting like WinAmp shoutcast on the PC-? I did a similar quesiton in another topic but I got as a answer -and thanks for this- a not so usefull piece of software with losts of limitaitons and it was for classic Amiga. If I find a stream solution for my Peg2 it woud be great I am going to set up a really good Amiga / Pegasos radio :)
    [ Edited by CountRaven on 2008/6/27 8:43 ]
  • »26.06.08 - 22:40
    With AmiNetRadio you can only recive Streams but you can't broadcast them.
  • »27.06.08 - 06:25
    Posts: 236 from 2003/7/28
    @ThePlayer...true but I think 99% of users only want to receive... :) So no worries. ANR works fine for me receiving internet radio... in fact I am listening to a stream now with ANR on my Pegasos-2 and it works fine :-)
    I just did a backup of my 1.4.5 sys: so I am ready for clean install of MorphOS 2.0 :-)
  • »28.06.08 - 16:00
    I was replying to countraven's post.
    I think he want's to broadcast a show with ANR but thats not possible afaik.
  • »28.06.08 - 19:00
    @ThePlayer,
    Yes I know. I was just commenting to your reply so he could read it.
  • »28.06.08 - 19:27
