internal cardreader and floppydrive in one
    amiga4001
    Posts: 454 from 2006/11/16
    There are these internal diskdrives with a cardreader combined.
    Anyone have one off these do they work?
    I don't want an external unit.
  • »05.05.08 - 17:41
    jcmarcos
    Posts: 1178 from 2003/3/13
    I've never seen one of those. You mean a card reader combined with a diskette drive? These later are useless today. MorphOS never had official support for the built in diskette controller in the Pegasos, although Sonic did wrote a driver.
    I happen to have on of those external multicard readers (even though I only use SD media), that being 3.5 " in size fits perfectly inside the diskette bay of my Pegasos I (April 2). It works very well with Poseidon which, of course, is no news.
    Being an external unit forced me to rework the cable, in order to plug it into the internal USB header, but it is very easy to to so. I remember having soldered the cables for an Amiga 500 expansion port extender, with 86 cables... God bless USB
  • »06.05.08 - 04:31
