Firmware for BlizzardPPC
    Charvel
    Posts: 97 from 2007/2/15
    Hello!
    While I was upgrading the firmware of my BlizzardPPC card my computer froze. Now the card doesnt start anymore.
    I have found people that can help me with an eepromburner but I still need the image-files for the eeprom.
    Does anyone know where I can get them?
  • »26.01.08 - 10:19
    Posts: 37 from 2008/1/4
    I believe what you're looking for is a flash / firmware update for the Blizzard 603e/603e+
    Look here:
    http://powerup.amigaworld.de/index.php?lang=en&page=13
  • »26.01.08 - 15:21
    Charvel
    Noop )=
    The flashupgrade doesnt help. The card doesnt start.
    I need a special file for programming the BPPC.
    After what i have heard DCE had that file but not anymore.
    I would be VERY happy if someone could help me find it.
  • »26.01.08 - 16:15
    Posts: 3311 from 2003/3/5
    Usually the 'force' argument given to the flash update command fixes the card. However, your MorphOS key will no longer be valid I'm afraid - and you won't be able to get a new one for this card.
  • »27.01.08 - 08:34
    Charvel
    @jacadcaps
    THANKS!
    The card is working! :) I thought it would never start again but now it runs perfectly!
    [ Edited by Charvel on 2008/1/27 19:41 ]
  • »27.01.08 - 16:41
