Widgets
    XzIt
    Posts: 250 from 2005/1/19
    Any programs or compability with widgets for Mac maybe?
    Would be cool if we had some  :-o
    X
  • »04.01.08 - 22:35
    Robin
    Posts: 741 from 2003/2/24
    widgets are an invention of amiga ... they are called
    commodities.
  • »05.01.08 - 08:53
    analogkid
    Posts: 715 from 2004/11/3
    There are some widget-like apps like April, CLONCK, Wetter (www.amigazeux.net) or statine (www.binaryriot.org)
    @Robin: I think Commodities and Widgets aren't really comparable, because Commodities can be run in background, without seeing them anywhere on desktop.
  • »05.01.08 - 09:53
    alfie
    Posts: 96 from 2005/3/25
    I think real transparency is needed to design cute widgets. So, I can see many little thingy to appear on the wb when mos2 is out.
  • »05.01.08 - 10:33
    XzIt
    Would be great if we could get some compability with Mac widgets.
    Instead of make lots of small replacments.
    would be able to just download widgets for mac and use them :D
    Maybe A Bounty is in order  :-?
    X
  • »05.01.08 - 11:32
    XzIt
    http://sourceforge.net/projects/wxwidget-aos/
    Whats this? can't seem to find anymore info
  • »05.01.08 - 15:08
    Posts: 2079 from 2003/6/4
    wxwindows is a graphic tool kit. You can use it like SDL, MUI, GTK or the MFC. The cool thing of wxwidgets is that it's basically a wrapper, i.e. a wxwidget app uses the native grapic toolkit of the actual system.
    wxwidgets for AOS is not ready (yet).
  • »05.01.08 - 15:58
    GK_LKA
    Posts: 481 from 2004/3/28
    OSX widgets are written in HTML+CSS+Javascript, with a few extra options (like possibility to run executables). I think some of the widgets could work if we had a working KHTML implementation.
    [ GK / LKA Team ]
  • »05.01.08 - 20:41
    XzIt
    ok, sounds like it could be done with a little effort.
    Anyone else wanna use widgets or just ME  8-)
    X
  • »06.01.08 - 13:04
    Posts: 1086 from 2003/3/24
    Widgets are not that bad, what i like the most about them is that you have a separate window, you can reach with a Hotkey or one of the edges. Thats a good idea to hide that tools cos you don't need them most of the time.
    But i would like to have the choice if they stay on top of Ambient or if they are reachable with a Hotkey like in OS X.
  • »06.01.08 - 14:09
    XzIt
    Me too, so many nice little Widgets.
    X
  • »09.01.08 - 15:41
