strbackdrop? A feature in MorphOS 2.0?
    XzIt
    Posts: 250 from 2005/1/19
    http://aminet.net/package/util/wb/strbackdrop
    This is something i really am missing now a days on MOS.
    Is this 68k package usable? or do we have something Mos Native that i haven't heard about?
    Will this feature be a part of 2.0? anyone know?
    X
  • »05.01.08 - 12:44
    warface
    Posts: 653 from 2003/2/24
    If this program is only about having random background images, then there are quite a number of alternatives out there.
    Haven't checked if it works on 1.4.5 but there's filepick, you can give it a go. I used it back then to have random MUI backgrounds.
    The trick is, the background image file path remains the same, you just replace it with another image. The user startup line that did the trick to me looked like:
    copy > NIL: `c:filepick Drive:Backdrops/#?` Drive:targetfile.jpg
    You stored the random backgounds in Backdrops, and set targetfile as your backdrop. It will be replaced with a random one at each startup.
    Hope it helps.
  • »05.01.08 - 12:57
    roschmyr
    Posts: 210 from 2003/2/20
    you can change the background in newer Ambient builds automatically
    Ambient-settings -> Background -> desktop
    select a dir with images and set time to change the background
  • »05.01.08 - 13:15
    Posts: 1060 from 2004/9/23
    You don't need to wait for MOS2.0.
    That feature is part of latest Ambient for quite a while.
    Just open Ambient Preferences and enter Background page. Instead of specifing a
    file specify a drawer with images.
    The slider below allows to setup the change rate.
    Geit
  • »05.01.08 - 13:15
    XzIt
    Can i plz have a option that says: "After every reboot" ?
    :D
    X
  • »05.01.08 - 13:45
    kiero
    Posts: 129 from 2003/2/28
    just select 'Never' in slider (leftmost position)
  • »05.01.08 - 14:39
    XzIt
    Thanks :D
  • »05.01.08 - 15:00
