EFIKA: Booting from USB Stick
    Posts: 655 from 2004/4/15
    Hello,
    i have got a new EFIKA. I plugged
    a Radeon 9250 and 2,5" IDE harddrive to it.
    Than i tried to boot from usb stick, but it does not
    work.
    devalias says that the USb stick is at hd0.
    show-scsi says that there is first the ide drive and
    second the usb stick.
    ls scsi
    ls hd0
    ls hd0:0
    no content is shown :(
    I formated the usb stick with vfat, fat32, ext2, ext3
    nothing works. I have tried three sticks, same problem.
    How should i configurate the usb stick that the partition is shown??
    (cfdisk number??, bootable??, primary???), which
    file system mkfs.???
    I really do not know what i can do now, because i have
    tested everything.
    [ Edited by eliot on 2007/12/26 8:29 ]
  • »26.12.07 - 06:06
    jcmarcos
    Posts: 1178 from 2003/3/13
    Try asking in Power Developer, we have little (if any) experience with Efika, because this is a MorphOS forum, which currently only runs on Pegasos and Amigas.
    What, you've already tried?
  • »26.12.07 - 10:42
    http://www.powerdeveloper.org/
    does not exist?!
  • »26.12.07 - 10:48
    Posts: 2732 from 2003/2/24
    does not exist?!
    I clicked on your link and it worked fine... :-)
  • »26.12.07 - 12:30
    Crumb
    Posts: 738 from 2003/2/24
    try out other usb pendrive. Efika's smartfirmware USB stack is quite good but it doesn't recognize correctly all devices
  • »26.12.07 - 14:07
    I have tried three usb pen drives.
    They are listed by show-scsi, but the partitions are
    not found.
    Should i really have a try with another
    pen drive???
  • »26.12.07 - 16:05
    SoundSquare
    Posts: 1214 from 2004/12/1
    pen drive???
    yes.
  • »26.12.07 - 17:15
    Ok,
    i bought a new usb pen drive today and it worked.
    There seems to be some problems in the OF to read the correct
    partition table.
    My be fixed some day?
  • »27.12.07 - 07:09
    icare297
    Posts: 1 from 2007/11/28
    I have the same problem. Which usb pendrivre did you bought ? What manufacturer ? Thanks.
  • »27.12.07 - 07:46
    I bought a pendrive from Atelco (no name) here in
    Germany for 7,90 Eur.
    The problem seems not the manufacturer but the partition
    table of the pen drive.
    Buy a new one, there you have got a clear partition
    table and everything is fine.
    Other solutions (withuot any costs) you can find here:
    http://www.powerdeveloper.org/forums/viewtopic.php?p=9862#9862
  • »27.12.07 - 08:03
    jcmarcos
    eliot wrote:
    The problem seems not the manufacturer but the partition table of the pen drive. Buy a new one, there you have got a clear partition
    Isn't there any way of wiping completely the partition table in this kind of device? I understand that the regular "format" command is of no use...
    Also, is the USB stack in SmartFirmware something like Poseidon, exactly Poseidon, or something completely different?
    [ Edited by jcmarcos on 2007/12/27 13:41 ]
  • »27.12.07 - 10:39
