    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 19.04.2011 - 08:40 ]
    Pegasos2 G3, 512 megs RAM
  • »20.10.07 - 11:14
    Genesi
    Posts: 239 from 2005/1/7
    Hi Velco: here it is:
    We wrote about it here:
    http://bbrv.blogspot.com/2007/08/photovoltaic-open-client.html
    R&B :-)
  • »21.10.07 - 11:49
    Posts: 1086 from 2003/3/24
    Wow all i can say is "COOL"!!!
  • »21.10.07 - 12:54
    Velcro_SP
  • »21.10.07 - 20:16
    Genesi
    Have a look:
    So, as long as this is ready too, we should be in good shape...
    http://www.youtube.com/watch?v=uXioGhnbmi8
    And this...
    http://www.youtube.com/watch?v=KOGnzn8XMq4
    Those are both EFIKA Open Clients using Linux. So with MorphOS you can just imagine the possibilities...
    R&B  :-)
    [ Edited by Genesi on 2007/10/22 0:53 ]
  • »21.10.07 - 22:44
    Posts: 2079 from 2003/6/4
    My current Efika1 setup draws about 25-30W (running but not under max stress). But I haven't tested the gfx card under 3d stress yet...
    Over the thumb that is a good 10W for the gfx card, a good 10W for the display and ~5W for Efika+hd.
    With an Efika2 it will be signifcantly less when using the 5121 gfx and no additional gfx card.
    On the display side I am hoping to reduce the energy uptake to the half (there are ways). My goal is to reach ~12W for the entire device operating (but not under max stress / display with medium load).
    Solar shouldn't be too much of an issue then.
  • »22.10.07 - 07:13
    Jupp3
    Posts: 1193 from 2003/2/24
    So when most people consider it better to use the computer on the cloudy days, you will be doing the opposite? :-D
  • »23.10.07 - 09:40
    Velcro_SP
    [ Edited by Velcro_SP 19.04.2011 - 08:39 ]
  • »24.10.07 - 07:24
