usb compatible hardware list
    amiga4001
    Posts: 454 from 2006/11/16
    I see there is a list (all be it small) for supported usb hardwaredevices with os4.0.
    Would be very nice if such a thing would exist on morphos.
    So compatibel with poseidon.
    Only have to make sure it would contain the most important data like:
    Brand type kind off hardware etc..
    Maybe after a while it could be uploaded to aminet?
  • »14.10.07 - 05:59
    Posts: 2209 from 2003/2/24
    I don't know if we need that kind of list as we don't have similar problems with USB like on OS4 ;) So far all USB devices I've needed (and which should work in theory) have worked.
    But OK, it might help to find if some hw is compatible with common standards or does it need non-standard drivers etc. Manufacturer doesn't say it always too clearly :)
  • »14.10.07 - 06:35
    guruman
    Posts: 461 from 2003/7/21
    There is a generic compatibility list at the Poseidon's home page:
    http://www.platon42.de/poseidon.html
    It's generic, but useful enough, since, as already stated, if a device
    respects the supported standard, it will work no matter the
    manufacturer. Poseidon is very good in this regard. Sadly sometimes
    the devices are not perfectly standard compliant (many wheels/pedals
    for car driving simulations won't work, because hot HIDD compliant -
    Thrust Modena 360 is known to work, for instance).
    Kind regards,
    Andrea
  • »14.10.07 - 07:49
    amiga4001
    I just recently purchased me a new mp3 player.
    I had to go back to the store and swap it 3 times to get a working one with morphos.
    Seems these kind off things are getting more and more windowsonly.
    That's why I would like such a list to exist.
  • »14.10.07 - 17:57
  • Ex-Member
    Posts: 74 from 2004/6/15
    Making a list of hardware that works with MOS 1.4.x, with a version of Poseidon thats close to two years old now (which sucks), with various versions of broken uhciusb.devices or even more broken ohciusb- and ehciusb.devices? Most users don't seem to be able to send in an errorlog or Devlister output, which isn't close to "real" bugreport.
    Why do I have the feeling that building a list of working devices not a good idea in the current situation...?
    Bye...
    Chris Hodges
  • »14.10.07 - 19:36
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 31.08.2011 - 09:05 ]
    Pegasos2 G3, 512 megs RAM
  • »14.10.07 - 23:33
    weiseb
    Posts: 212 from 2003/3/29
    @platon42
    Like you pointed out the Morphos 1.4 version is a lot older than the current Amiga-Version, so even if I had a problem with poseidon I may would not have contacted you thinking: maybe its already fixed and if not I could not even test a new bugfixed version an Mos 1.4
  • »15.10.07 - 01:31
    amiga4001
    samsung mp3player YP-U2/U2R 1 GB works 100% with the massstorageclass from the 68k latest poseidon release.
    I know it ain't recommended to mix these but it works ok.
  • »15.10.07 - 17:39
    Kaczus
    Posts: 199 from 2003/9/6
    I've bought iRiver T60 / 1GB, play: MP3,WMA, OGG, ASF, has also FM
    tuner and recorder. After upgrading firmware to newest it works with
    Morphos 1.4.5 without any problem.
    Kaczus/BlaBla & AUG-Lodz Happy Pegasos User
  • »16.10.07 - 14:25
