Battery lifetime
    Brumiga
    Posts: 270 from 2004/4/3
    Hello,
    I own my peg2 since 3 years and half and I use it daily 3 to 4 hours, sometimes 6 hours. What is the battery lifetime in these use conditions ? What will happend when the battery will be in low voltage ? Will the peg be able to boot at least to open firmware ? When changing the battery will open firmware settings be preserved or not ?
    Brumiga
  • »30.09.07 - 08:31
    Schlonz
    Posts: 131 from 2004/4/16
    This question is somehow special - I dont think that any of us "normal" Peg users will be able to answer this.
    Better ask bPlan via Email. Usually they answer within hours.
    Then post their answer here ;-)
  • »30.09.07 - 16:25
    CLS2086
    Posts: 168 from 2005/8/25
    Hi Bruno,
    the battery can last long up to 10 years, but it's safe to change it after 5 years.
    Keep the Faith !
    VG 5000/A1000/500/500+/600/2000/1200PPC-GREX/1200PPC-ATEO/1200+1230-IVFPUSCSI/CD32/Pegasos 1 April1 G3/Pegasos 2 G4/ Ahtlon/K6-3/various funny machines too  :-)
  • »30.09.07 - 18:14
    jcmarcos
    Posts: 1178 from 2003/3/13
    Easy: Replace battery with care, when system is running. Can it be dangerous?
  • »01.10.07 - 05:02
    Posts: 140 from 2003/9/16
    Recommending a user to mess with the pegasos sensitive parts while IT IS running is always a bad idea.
    It fairly easy indeed. If you feel unsecure about your battery may be slowly getting dead, just buy a new one, and just replace it ( while the machine is powered off, of course )
    AFAIK -AFAIK- the ram powered by the battery, lasts at least, a minute to get erased by lack of power (aka missing baterry) , so IMO you have enough time to replace it.
    [ Edited by FrankBrana on 2007/10/1 12:09 ]
  • »01.10.07 - 11:04
