Wi-Fi on MorphOS?
    Phantom
    Posts: 381 from 2004/9/7
    Just a simple question, does anybody knows if I can have Wi-Fi on MorphOS. Is there any PCI card and what you recommend, which is working on MorphOS and what about software? Thanks... :-)
  • »20.09.07 - 10:35
    Posts: 2209 from 2003/2/24
    Check prism2 device from Aminet:
    http://aminet.net/package/driver/net/prism2
  • »20.09.07 - 11:37
    catohagen
    Posts: 297 from 2003/5/20
    I've used a wireless client, i.e a box/router
    that connects to the access point and you just
    plug in the cable. Either you can buy such client,
    or you can get a cheap router thats 'hacked' and
    replace firmware that allows this client mode.
    The advantage with this is you get full wireless
    speed, works with any computer/device that have
    ethernet, supports higher security encryption
    and its easyer to set up in morphos :)
  • »20.09.07 - 14:01
