Posts: 118 from 2003/2/24
Hi everyone,
just wanted to let you know that I successfully tested a Pegasos 1 with an affordable fanless external 60W power supply unit.
Finally, the dream of a *silent* and economical Peg1 came true :)
In case you're interested, here's the setup :
Peg 1, G3, radeon 9250, DVD drive, harddrive.
You may have a look at the PSU here : (in French, sorry) http://www.think-itx.com/kit_alimentation_fanless_%5B60w%5D-100-1-c.html
From here, it's possible to remove the DVD, replace the HD with a compact flash with CF->IDE adapter, add a riser card, build one's own mini case, to get a super Efika ;)
cheers,
mahen
xmpp:mahen on jabber.fr
