PCI IDE card support.
    nine
    Posts: 46 from 2006/6/14
    Are there any PCI IDE cards that MorphOS supports? I would like a little extra capacity in my system to attach another drive or two, but I'm concerned that any controller I buy may not be compatible.
    I'm not looking to be able to boot from SmartFirmware with said card, but I would really like the drives attached to it to be available to MorphOS!
    On a similar note, has anyone had any luck with Serial ATA cards?
  • »01.06.07 - 11:11
    nine
    I'll take the silence to mean "no" then :-)
  • »03.06.07 - 08:24
    analogkid
    Posts: 719 from 2004/11/3
    Maybe you could take a SCSI-Controller together with an Acard IDE-SCSI Adapter to use an extra UDMA-drive?
  • »03.06.07 - 22:47
    nine
    That sounds crufty :-)
    I wanted to avoid using SCSI-IDE adapters, because I intend to use an IDE-SATA adapter.
    I can imagine the adapter chain growing to a silly length!
  • »04.06.07 - 05:54
    Schlonz
    Posts: 131 from 2004/4/16
    Another solution would be an external HDD connected via USB2.0 to your peggy. Probably not as fast as conntected directly to the motherboard or via a PCI IDE card, but I get about 10 MB/sec with my old 30 GB HD which I connected via an USB-to-IDE-Adapter.
  • »04.06.07 - 20:07
