Posts: 2217 from 2003/2/24
I have found couple of working 256M DIMMs for Pegasos1 (April2), but they seem to work alone only, not in pairs in any configuration. I'd like to have more memory and I've tested couple of used 512M DIMMs... without luck.
I decided to buy expensive Kingston memory, which was reported as "fully working memory" here at tutorials section.
It was this:
Kingston
512 MB
KVR 133X72RC3/512
512 MB PC 133 Reg. ECC DIMM CL3
It arrived today, but for my great disappointment it doesn't work :( HD led keeps on and OF prompt won't appear. I tried it on both slots, no effect. And together with one working 256M module... for a surprise, OF prompt appears, but neither MOS or Linux will load.
I've bought the memory as a new one. It came on plastic case with user's guide and Kingston's seal, but there were single scratches on contacting surfaces, like it would have used once somewhere. Suspicious or do they test mems at factory?
So now I'm a bit clueless... is the module broken or isn't it compatible afterall? Could Kingston have changed the chips to different brand which would make it not compatible? Should I look the actual chips instead of the reported model (which seems to be pretty hard as PC133 mem can be found only by ordering)? Why wasn't it reported on this one on compatibility list?-)
Seems that this memory has Samsung K4S560432H-UC75 chips.
For a curiosity, at least these 256M DIMMs seem to work (alone):
TwinMOS PC133 256MB SD/CL3
(Samsung K4S2808320-TC75)
Hyundai PC133U-333-542 HYM71V32635 AT8-H AA 256MB Sync 133MHz CL3. Also has IBM logo on other sticker.
(Hyundai HY57V28820AT-H)
I have two of these, but still won't work together.
BTW. it's said that regged mem would be good for Peg1. Anyone knows if that affects to stability or anything in practise?
