Possibly the ugliest Efika case/holster ever..
    Tronman
    Posts: 209 from 2003/3/3
    ...But it works!
    Here's the URL, I made an album of my adventures making this thing on webshots.com..
    http://community.webshots.com/album/557589369ZQViMI
    It won't win any design awards with its 1960s surplus power and reset buttons and scrounged LEDs/parts of an AT case and ATX power supply. However the whole thing cost me $10 for the microATX power supply and a day's worth of futzing around, and it was entertaining. Now, it waits only for MOS 1.5 :-D
    The long term plan is for this to go inside a much more elegant case, but that will take time to build so for now, this is it. I just didn't want the graphics card flopping around while the machine was on..
  • »12.02.07 - 03:51
    fairlanefastback
    Posts: 54 from 2007/2/6
    Good stuff Tronman!
    What did you use to cut the metal for the ports and then shape it well if I might ask?
  • »12.02.07 - 04:10
    Tronman
    Heh, Thanks :-)
    I used a chainsaw file for the bigger round holes, and a kit of small files from Radio Shack, one of them is a triangle shape so it's easy to make corners with. Plus, the soft steel of the case is easy to work and soft to grind.
    I cut the USB/ethernet square hole out with a dremel tool and fiber disc attachment, since the opening was large enough to use one.
  • »12.02.07 - 04:45
    amiades
    Posts: 231 from 2005/6/2
    I love the big buttons xD... they are saying "push me!".
  • »12.02.07 - 06:23
