Ericsson m600i & MOS ?
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    Anyone using this combination ?
  • »13.12.06 - 13:22
    Motosampy
    Posts: 199 from 2004/8/14
    Yes, I am.
  • »13.12.06 - 15:04
  • pOS
    pOS
    Could you please tell me if it is detected as an USB Drive under MOS ??
  • »13.12.06 - 18:51
    Posts: 98 from 2004/6/4
    I'm using SE P990i with MOS quite good. It fails to work with linux, but with MOS works perfect.
    WBR, Vladimir Berezenko
  • »14.12.06 - 04:56
    MrZammler
    Posts: 18 from 2003/3/3
    M600i and P990i should work fine in linux with kernel 2.6.18 (as a usb storage device)
  • »14.12.06 - 12:31
    Posts: 1084 from 2003/3/24
    What about the K800i???
  • »14.12.06 - 13:08
    Motosampy
    M600i works perfectly under MOS as USB massstorage device (except when conneted to my USB2.0 ports, but that't because of the primitive driver).
    Had problems with Ubuntu linux, can't remember kernel version though, nowadays have replaced Ubuntu with Fedora Core 6 and everything works fine.
    If I remember, I'll test a K800i tomorrow and tell...
  • »14.12.06 - 18:34
  • pOS
    pOS
    Great to here. After reading some comments in Linux and Mac Forums it seemed, that it wouldn't work. I also read that under Windows XP you would need to install drievrs to mount as an usb drive.
    Some more questions:
    1. Which Firmware version does your Phone use ?
    2. Did you have to do any special settings in Poseidon or did it work 'out of the box' ?
    3. I have all my MP3s encoded with a variable (!) bitrate, maximum 320 KBit/s, joint stereo.
    I wonder if they can be played or if I have to encode with other settings.
    4. Does it have a 3.5 mm connector or at least an adapter to use generic headphones ?
  • »14.12.06 - 19:07
    kriz
    Posts: 310 from 2005/10/18
    I dont have the phone but no problem playing vbr files in Aminet Radio or another mp3 player...
  • »14.12.06 - 22:52
    Don't read various crap. 8) The both phones work perfect in Linux and MorphOS. To make them work in MacOS you just need to dload an update from Apple site. The problem exists only in Debian, and only with kernel higher than 2.6.12. It has a bug in usb-storage kernel module.
    1. P990i's latest. Anyway everything worked even with the first.
    2. Everything works out of the box. You just need the fat95 in L:
    3. Should play. Mine plays.
    4. Just go to the shop and ask for it. I don't remember it's part number...
    BTW, have you switched the phone in ^->connections->USB to file transfer. It might be set by default to phone mode. So as we have no OBEX support in MorphOS it will not work.
  • »15.12.06 - 03:28
    Motosampy
    I quote QMaster, except that I have m600i.
    I use my M600i with Koss Porta Pro headphones.
  • »16.12.06 - 13:19
  • pOS
    pOS
    Thanx for your answers. That helped me a lot. I have now ordered the phone :)
  • »16.12.06 - 14:35
