Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Hardware
EFIKA HARDWARE
serge
# 1
Posts: 725 from 2003/2/20
Would like to know which is the USB used on EFIKA. Is it USB 1.1 or USB2 ?
I dond found this information on genesi sites.
24.11.06
03:58
Posts: 2728 from 2003/2/24
It's 2x USB 1.1.
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MPC5200B
MorphOS is Amiga
done right!
MorphOS NG will be AROS
done right!
24.11.06
05:14
tarbos
# 3
Posts: 221 from 2003/4/19
@Serge:
If you are interested in the hardware, you can read
the report at PPCNUX
Furthermore there is new material at
Power Developer
with info about modem connector, different signal configurations at the IrDA port etc.
24.11.06
06:14
