Resize 160 GB Partition with Marek Szyprowski resize tool?
    dIGIMAN
    Posts: 273 from 2005/11/7
    Hi Guys,
    at the beginning i sized a harddrive, which is quite full,
    to use its full space in one partition, which is 160 GB.
    There is a tool by Marek Szyprowski, which is
    able to resize a partiton. Will i be able to resize my hd to a save size (eg. 120 gb), without loosing data?
    Its not easy to backup 100 gb b4, so it would be great if this is possible.
    Ofcouse nobody can be sure, if everything always works fine, but maybe its an bad idea anyway, as the partition is out of sfs limits from the begining.
    Maybe somebody can help me with this
  • »21.10.06 - 11:56
    tokai
    Posts: 1289 from 2003/2/25
    well.. first of all i recommend to make a backup (its better that way, before you lose data).
    Anyway... I have no idea if the tool works or not, but I suggest to defragment (with Defrag) the partition first, so all data is at the beginning of the partition and not randomly all over to the end of it.
    Second make a backup of the RDB. (Save at least the SCSIconfig.RDBStorage from SYS:Tools/ ), so you might be able to restore the partition size and try SFSSalv after.
    And then try and pray. ;)
    But you better make a backup. I don't know what the 100GB data are.. backup at least the important data... the 95GB pr0n you might lose in worst case are not so important as the other 5GB. ;)
    regards,
    tokai
  • »21.10.06 - 14:21
    merko
    Posts: 328 from 2003/5/19
    I'm not sure running defrag first is a great idea, surely this would risk triggering >128GB overflow problems..
  • »21.10.06 - 21:32
    dIGIMAN
    Just wanted to let u know, that everything worked out.
    SFSDoctor always frooze, on the orginally partition to fix :(, but i was able to shrink the 160gb partition to 120gb without problems and loosing data :)
    Thank Good, as i didnt do any backup.
    And no, it was no porn :)
  • »23.10.06 - 10:25
