Posts: 568 from 2003/2/24
Hello everybody,
I started this on the mailinglist and now here
I really would like the printing work on the Peg.
As mentioned on the mailinglist, my colours are inverted, printing a document is white on black.
As you can imagine this a pretty expensive business per page!
Trying to print a colour picture, results also in inverted colours.
I've tried the inverted colouring in the TurboPrint Prefs, but this doesn't work. Also tried reversing colours, but that also doesn't work.
I've got a HP920C with a real PC-cable.
With my A1200 I don't have trouble printing stuff with the printer.
I was thinking it was a problem with my motherboard until someone mentioned the same problem on the mailinglist.
Is there a solution for this?
Spidey
