Looking for a new Case for the Pegasos II
    Posts: 1932 from 2003/10/19
    i'm looking at several cases online at newegg.com and want to make sure I get one that will fit the Pegasos II main board well. I want a small footprint case. They have several nice looking Micro ATX cases. Will most of them fit the Pegasos? What do i need to look for so I dont have to return one?
    [ Edited by Acill on 2006/7/22 15:36 ]
  • »22.07.06 - 21:29
  • phx
    phx
    Posts: 70 from 2005/3/29
    I think MicroATX cases should fit nicely, as long as you don't have
    more than one hard disk and a CD-ROM installed.
    You find photos of my PegasosII in an AOpen A340 MicroATX case here:
    http://sun.hasenbraten.de/~frank/computers/pegasos2.html
  • »23.07.06 - 09:25
    SoundSquare
    Posts: 1214 from 2004/12/1
    all micro atx cases should fit. I had 3 different micro-atx cases for my peg and i never had any issue. But yes, keep in mind that not all cases will allow you to use several HDs.
    my pegasos case
    again
  • »23.07.06 - 10:02
    Pypo_Pere
    Posts: 20 from 2005/11/15
    Only one question SoundSquare:
    Where you bought you morpos sticker that your have in your tower, and how mach does it cost?
    Pypo
  • »23.07.06 - 13:56
    magnetic
    Posts: 2129 from 2003/3/1
    Hi Acill
    I can give you a good deal on an In the Box Antec Aria cube case. Also, you remember my case I brought over? I can sell you that one for a good deal too. Best part is you know they fit the peg well  :-D
    I have 2 other cases I might xfer my peg into so these are for sale. I also have 1 of the really cool Coolermaster alumunium cases from the betatester days..
    magnetic
  • »23.07.06 - 14:09
    I found the new case I want. What do you all think?
    http://www.directron.com/xqpackbk420.html
  • »23.07.06 - 18:22
    magnetic
    Looks cool Acill
    Thats the cases Gunne from GGS uses afaik
    magnetic
    ps : c my email :)
  • »23.07.06 - 18:29
    SoundSquare
    @Acill
    classic ! this case is a reference among cube shaped microatx ones.
    nice choice.
  • »23.07.06 - 18:32
    SeaScape
    Posts: 6 from 2006/3/20
    We use the Aspire case for our Linux/Windows computers and it is simply awesome IMHO! The removable motherboard tray is worth it alone! It looks really great too!
  • »02.08.06 - 23:54
    AKiLL
    Posts: 93 from 2006/3/6
    My Aspire X-Qpack case is great too for its design and technical specs ...
    The only contra is that under both MorphOS and Debian Linux just one of the rear usb access port works while the other rear and both the front usb ports don't work :-(
  • »03.08.06 - 05:18
    Brumiga
    Posts: 270 from 2004/4/3
    Hello guys,
    Acill, i read somewhere on the net a few months ago a report in french. It said that this case is correct excepted the reset button too small for pressing with fingers. So a pen is needed to perform a reset. This little detail maybe annoying so i warn you about it.
    Brumiga
    [ Edited by Brumiga on 2006/8/3 14:17 ]
  • »03.08.06 - 11:16
