3 questions
    rigardie
    Posts: 45 from 2006/3/21
    Hi I have 3 questions to make
    First I have a double layer DVD+-R I want to use it with morphos is that possible?
    Second I am new in AMIGA OS so I need a good morphos-AMIGA tutorial exist any? . Finally question
    Which is the best morphos Game?
    Thanks
    [ Edited by rigardie on 2006/5/28 23:42 ]
  • »28.05.06 - 21:39
    gunne
    Posts: 441 from 2003/2/25
    Hi rigardie,
    1: I cant remember I ever have found any DVD/CD/DVD-RW etc, that works to use in one operating system and not with another operating system on the same computer.
    2: There is the Pegasos book - http://www.wikipeg.org/ - otherwise documentation for software is usually to find with the software.
    3. Birdie shoot :-)
    [ Edited by gunne on 2006/5/29 10:05 ]
    Best wishes, Gunne
  • »29.05.06 - 07:04
    beanbandit
    Posts: 50 from 2006/4/19
    1.Well morphos is probably the exception :-)
    The morphos support for DVD/CD +-R/RW is poor too say the least, for instance SCSI-Config doesn't understand Optical units, it insists that those are read-only (this might have been OK in 1994, but not in 2006, h*ll I would say it would have been bad even in 1987, IIRC WORM's was avaible roughly at that date.)
    there is no way to format/use DVD-RAM, there is no inbuilt facility to format/use DVD+-R/RW as in OS4 with Mt. Rainier. And to put it bluntly, this is pretty damaging for any 'modern' OS... and SCSI-Config is pretty much simply awful by any standard.
    hopefully 1.5 will correct most of that... but I doubt SCSI-Config will be changed... perhaps a bounty? :-)
  • »29.05.06 - 08:16
    gunne
    Beanbandit,
    But then You are talking about software to use.
    And yes, more good software is useful.
    Best wishes, Gunne
  • »29.05.06 - 09:15
    Jupp3
    Posts: 1193 from 2003/2/24
    Well it WAS extremely poor... In version 1.4 you couldn't read a DVD beyond 4GB, but luckily that was fixed in 1.45 version...
    Well, I don't think you should blame SCSI-Config for that... Afaik the drives are NOT handled like "normal" RW drivers, such as HD's but depend on additional support from the OS / external programs. You wouldn't use SCSI-Config to write to disc anyway, would you? :-)
    And it's still OK for most users. If you want to write a DVD, you can do so with FryingPan (shareware software), which will also result in a MUCH more compatible disc (DVD players etc.)
    Never understood the great big difference of dragging files & drawers to disc instead of disc writer window... Except that the later one will use space more efficiently, and can burn more compatible discs, of course.
    Who cares whether or not it's built-in or not? And I guess that this "built-in" is a separate program supplied with the OS (only sensible way to do it anyway)
    as in OS4
    I kinda saw that one coming :-)
    I guess we all agree on that. Good thing you don't have to use it often.
  • »29.05.06 - 10:02
    Posts: 2072 from 2003/6/4
    beanbandit wrote:
    [snip]
    [snip]
    IIRC there is a DVD-RAM handler in Aminet somewhere. Don't know where and how good it works (no DVD in my Peg), but I remember I heard some ppl talking about DVD-RAM usage under MOS and that it is *no* prob...
    edit:this should be the one I was thinking of: http://de4.aminet.net/disk/misc/DVD-RAM.readme
    [ Edited by Zylesea on 2006/5/29 13:57 ]
  • »29.05.06 - 10:50
    gunne
    Zylesea,
    This link works better: http://www.aminet.net/search.php?query=DVD :-)
    Best wishes, Gunne
  • »29.05.06 - 10:58
    beanbandit
    I know about that one... I was the one who said it existed... unfortunately it doesn't seem to create DOSDrivers that work under morphos.
    also there is a newer version to that that is called
    MakeDrivers
    http://main.aminet.net/disk/misc/MakeDrivers.lha
    there is supposed to be floating around a even newer version to that one version 1.5 I think... but I can't seem to find it.
  • »29.05.06 - 11:13
    merko
    Posts: 328 from 2003/5/19
    I'm interested in knowing what you'd use such DVD write-support for.
    I'm not saying it's a useless feature, maybe it could help someone
    sometime, but I don't really understand in what situation.
    Personally I burn DVDs to make backups or to archive data that I don't
    need to have immediately accessible, or to burn discs with data that
    I want to give to someone, or to create movie DVDs. In each of those
    cases I find it more convenient to use a dedicated program that uses
    the space efficiently and supports the special options that exist for
    DVDs opposed to "general" writable media. In fact, I'd want to turn
    off a built-in DVD write support, because it would be extremely
    frustrating to accidentally drop a file on the DVD icon and thereby
    create a "coaster".
  • »29.05.06 - 11:26
    beanbandit
    any formating or preparing of disc's should be done through the OS relying on 3'rd party software for it as a MUST is simply wrong (remember Burn-IT? where would morphos be without frying pan?), what if Frying Pan suddenly turns out to begin thrashing hardware (CD/DVD Drives)... and the developer stops developing it... what are you then going to do? boot into linux everytime you want to burn a CD/DVD? not the greatest advertising of a new OS (buy/run morphos... but remember to boot into linux every time you wan't to prep or format a DVD-RAM, Zip, Jaz2, REV or similar... because morphos doesn't like removable media)
    eehhh... and then it would be ok for you to have to boot into linux to read/burn a DVD-ROM too? so what's the big deal with reading larger DVD's than 4 GB... use Linux...
    eehhh.... who should I blame then, ide.device/symbios.device (which would make it even more serious)? when it comes to DVD-RAM they are nothing else than something similar to Zip Disc's (in a larger size)... are you saying that Zip's, Jaz/Jaz2's, Orbs, REVs, MO's, WORM's or tape drives shouldn't be possible to be used under Morphos?
  • »29.05.06 - 11:35
    Jupp3
    Well, considering the present situation, probably most users prefer "Working, separate, released 3rd party software" to "unreleased version of the OS, which MIGHT have that feature".
    Also, I guess it might be possible to do it "OS4 way" with 3d party software aswell, if someone just coded something like that... I just can't see any reason why. "Too many better things to do" :-)
    All of those are obsolete, Mt. Rainier is just useless :-D
    But seriously... Maybe "someone somewhere" would have some use for those aswell, but I can't think of any such person, but I sure can think of MUCH more important features, that could be added.
    And note that I'm not saying that they *shouldn't* be supported, only that there's no *need for* support. Anyone is free to add support for ANY hardware.
  • »29.05.06 - 12:39
    merko
    > added.
    Indeed. In the "removable media" section, I'd surely appreciate a
    fat95 filesystem as standard much more than DVD write support (I
    don't really consider CDR/DVDR as "removable" in the classic sense,
    it's more a backup medium IMO).
  • »29.05.06 - 14:54
