monitor analysis+morphos
    rigardie
    Posts: 45 from 2006/3/21
    Kalime'ra ,today it is the first day with my precious pegasos2!!! unfortunately mo'njtor that I have it is old 15 "PC and rather it does not support the analysis that it has installed morphos I would want to ask if it exists somebody mode as the safety mode that they have windows so as to I enter and I lower analysis
    please help me !!!
  • »19.05.06 - 22:15
    C64Days
    Posts: 103 from 2006/2/27
    Hi rigardie, first of all "analuse" in english is "resolution", and please
    tell us whether the OpenFirmware screen appears correctly at boot
    or not (it is the black screen with messages).
  • »19.05.06 - 22:59
    rigardie
    hi yes the first screen appears (with some words) but after that my monitor not works(it works 1000% with my 2 PC's)
  • »19.05.06 - 23:06
    C64Days
    What happens if you boot from Morphos CD?
    (enter the CD in the main CD/DVD reader of
    your IDE chain to boot from it and type "boot"
    from the OpenFirmware prompt).
    You can also try with any Linux Live CD/DVD
    (links and docs on www.ppczone.org).
  • »20.05.06 - 09:41
    merko
    Posts: 328 from 2003/5/19
    Ok, it can be:
    1. Graphics card problem
    What is your graphics card? Radeon XXXX, Voodoo X, etc?
    2. Monitor problem
    What is your monitor name exactly?
    The standard screenmode in MorphOS is low resolution, so it should
    work even with an old monitor.
  • »20.05.06 - 13:55
    rigardie
    ATI Radeon 9250,my monitor is 15" old pc bilenia
    according to the instaler my moprhos instalation mode is 1280x12024@60Hz.(may be the resolution is not the appropriate with 15" very old monitor
  • »20.05.06 - 15:32
    merko
    What installer is this? Where does it say 1280x1024?
    Do you have a MorphOS installation CD? Which version?
    It should use maybe 640x400 or so.. I don't know of any MorphOS
    installer that uses 1280x1024. Your monitor should work fine.
  • »20.05.06 - 16:07
    C64Days
    Does that graphics card work in your PCs?
    Stop the boot process by pressing "Esc" key
    and press "F9" key, this switches the OpenFirmware
    console to an higher resolution, does this work?
  • »20.05.06 - 17:15
    guruman
    Posts: 461 from 2003/7/21
    My guess is that he is saying that the reseller preinstalled MorphOS and set the res to 1280x1024x60Hz. My guess is that this resolution is not supported by his old 15 inches monitor, so either he goes to the reseller and asks him to lower the resolution to 1024x768, or he lends a 17 inches monitor from a friend and lowers the resolution himself. There's a good chance that everything might work afterwards.
    Kind regards,
    Andrea
  • »20.05.06 - 18:07
    merko
    Yes, or maybe he bought a used Pegasos.
    But in any case, he should have a MorphOS install CD.
  • »20.05.06 - 18:31
