DVI support in MorphOS?
    MorphDelf
    Posts: 274 from 2004/2/20
    I am wondering about if there is any of the ATI Radeon cards that MorphOS supports which includes a DVI output connector?
    I am asking about this, as it would be very interesting seeing MorphOS on a Apple or Dell etc Cinema 20, 23, 30 widescreen monitors. Especially drawing in TvPaint, having such big drawscreen would be superb!
    Could someone tell me if MorphOS support it, or does MorphOS support it directly as DVI dosent really need external drivers?
    Regards,
    Michal
    [ Edited by MorphDelf on 2006/5/2 9:43 ]
    [ Edited by MorphDelf on 2006/5/2 9:44 ]
  • »02.05.06 - 06:43
    Henes
    Posts: 507 from 2003/6/14
    http://www.amiga-news.de/en/news/AN-2003-08-00047-DE.html
  • »02.05.06 - 07:11
    MorphDelf
    Thats nice. Thanks for the answer.
    I wish you all the best :)
    Regards,
    Michal
  • »02.05.06 - 07:20
    GK_LKA
    Posts: 481 from 2004/3/28
    Radeon 9200SE DVI output works fine here.
    [ GK / LKA Team ]
  • »02.05.06 - 08:05
    MorphDelf
    I am thinking of buying a Apple Cinema 20", 23" or 30" :) I am not sure which one yet. Dell ones are cheaper, but then its the design ;p Maybe I just dont like Dell because of their bad adverts on National Geographic Channel ;P Well, nice to know that MorphOS supports it.
    Will a screenmode like 1680 x 1050 work fine etc?
    Regards,
    Michal
  • »02.05.06 - 08:16
    SoundSquare
    Posts: 1214 from 2004/12/1
    Apple Cinema Display screens are overrated in my opinion. The design is nice but the specs are under today's standards for a higher price. I'd go for Dell.
    edit : typos
    [ Edited by SoundSquare on 2006/5/2 11:26 ]
  • »02.05.06 - 08:25
    Donar
    Posts: 142 from 2003/12/27
    I have a Dell 2005 FPW currently driven over DVI in 1680 x 1050 @60Hz no problems with that. But i think you can not go much higher in Resolution because of the Driver or something. So you could have Problems with a 23/24' as far as i know eg. 1920 x 1200 is not possible.
    Bye
  • »02.05.06 - 10:38
    GK_LKA
    Well, a little bit offtopic: I've tried out - just for fun - one old Amiga thingy on my Peg: the Autoscroll feature. I can tell you, that it doesn't work for me. :( If I set up bigger than 1600x1200 screen, strange effects come up (Pointer goes out in the right corner and comes in in the left, background is corrupted, etc.). :(
    [ GK / LKA Team ]
  • »02.05.06 - 21:00
    yashin71
    Posts: 37 from 2004/4/20
    How can I activate the DVI on MorpHOS?
    I have an ATI 9250.
    Thanks for the help
  • »04.05.06 - 13:42
    GK_LKA
    Try MOSSYS:Devs/Monitors/Radeon file's DVI_ENABLE=YES tooltype.
    [ GK / LKA Team ]
  • »04.05.06 - 14:03
    yashin71
    yes it is activated but nothing doesn't appear
  • »04.05.06 - 14:07
    jdryyz
    Posts: 127 from 2004/4/9
    I'm using a Sapphire Tech Radeon 9000 AGP and DVI is working for me also (without modification to MOS) although I have to admit I am using the standard VGA output instead-- the reason being that the DVI doesn't look quite right. It almost has a look that seems to be "too digital". I don't recall exactly if MOS showed signs of this, but I definitely recall it manifesting itself in OS X (through MOL) as well as Gentoo Live and Ubuntu. The best way to describe it is a pixelated appearance in graphics/gradients. Almost as if you swtiched from 32bit color to 16bit color.
    I am looking to get a hold of a true ATI branded Radeon 9000 to see if it just my card doing it.
  • »04.05.06 - 15:48
    BatteMan
    Posts: 290 from 2003/2/24
    If you want to use DVI, don't forget to buy a good DVI cable. It's 50% of the quality, or more !
  • »04.05.06 - 16:05
    Brumiga
    Posts: 270 from 2004/4/3
    Hello guys,
    @Yashin71, there exists 5 kind of dvi to vga adaptors. On the french forum of AmigaImpact you can see on this topic www.amigaimpact.org/modules/newbb/viewtopic.php?topic_id=3221&forum=1 that someone gave a link www.tomshardware.fr/qualite-des-connexions-dvi-nvidia-et-ati-assurent-ils-article-3d-820-8.html about the different kind of adaptors. Maybe does there exist a similar article in english, try with google or other to find them.
    Brumiga
    [ Edited by Brumiga on 2006/5/4 19:09 ]
    [ Edited by Brumiga on 2006/5/4 19:10 ]
    [ Edited by Brumiga on 2006/5/4 19:12 ]
  • »04.05.06 - 16:09
    jdryyz
    I received my ATI-branded Radeon 9000pro 128M today and the DVI does look much better. Guess the Sapphire didn't do so well in this area.
    Now I just got to get a quieter fan. :)
  • »13.05.06 - 21:32
