distorted sound on peg 2
  • tom
    tom
    Posts: 149 from 2003/7/22
    I'm having troubles playing sounds
    When I'm playing sounds and moving windows or scrolling,
    my cpu rises to 100% and the sound distorts or fully stops
    I'm using a soundblaster audio card using the emu10kx driver
    However the onboard ac'97 also distorts the sound
    I'm using a radeon 7000 agp videocard
    any ideas of how to solve this?
    or what may be wrong
    regards, Tom
  • »29.04.06 - 17:42
    CLS2086
    Posts: 168 from 2005/8/25
    hi,
    do you have installed the 3D drivers pack ?
    are you sure of your PSU and your PSU plug ? it can be a problem with the " -12v ".
    Dont 't use the 1st pci slot next to the AGP slot.
    Keep the Faith !
    VG 5000/A1000/500/500+/600/2000/1200PPC-GREX/1200PPC-ATEO/1200+1230-IVFPUSCSI/CD32/Pegasos 1 April1 G3/Pegasos 2 G4/ Ahtlon/K6-3/various funny machines too  :-)
  • »29.04.06 - 17:49
    Donar
    Posts: 142 from 2003/12/27
    I had this problem with on board audio. But "fixed" it with installing a Soundblaster. Strange that you have problems with the soundblaster too.
  • »29.04.06 - 18:06
  • tom
    tom
    How can I control that PSU thing?
    I can ask my son, he knows much more of computers then I do.
    Regards Tom
  • »29.04.06 - 19:11
    Posts: 1521 from 2003/2/24
    It is not PSU related.
    What apps you are scrolling when distortion happens? With Voyager it is prominent but shouldnt happen otherwise... (it can happen sometimes though).
  • »30.04.06 - 09:05
    merko
    Posts: 328 from 2003/5/19
    It should also happen with CygnusED. It runs at pri 1 as standard, as
    Piru informed me some time ago. If you change it to pri 0 it won't
    cause any sound distortion.
  • »30.04.06 - 09:36
  • tom
    tom
    The distortion is with every window and every program. The bigger the window the bigger the distortion.
    Is it possible that there is a problem with the Radeon-card?
    regards Tom
  • »30.04.06 - 17:54
    deez
    Posts: 53 from 2003/5/28
    @Tom
    I have the same situation, I use Radeon 8500.
  • »01.05.06 - 15:19
  • tom
    tom
    Is this a problem with every Graphic-card? I'm using my Pegasos not only for DTP (Pagestream) but also for recording sound and to play MP3's.
    regards, Tom
  • »01.05.06 - 15:50
    hooligan
    Posts: 1948 from 2003/2/23
    I have Radeon 9100 and Peg2.. no problems whatsoever with sound. Though on Peg1 I did have the descriped problem.
    Maybe you have a secret Articia hidden as an easter egg ,-)
  • »01.05.06 - 16:05
