WD Raptor on PegII
    Sukkulento
    Posts: 40 from 2004/4/6
    Yesterday I bought a SATA controller to try an axperiment with SATA disk (WD Raptor). Debian Linux recognize perfecly both controller and disk, The installation end without problems but when I try to reboot the system, the OF does not find the kernel to boot.
    At the end of installation Debian suggest to reboot with boot /pci/scsi/disk@0,0,0:1 boot/ root=/dev/sda2 but doesn' work!!
    I confessed I'm not a fox with OF commands, but what kind of command shows the partitions on a scsi disk?
    The disk is very fast...the installation ends in 10 minutes...!!! I think on a normal work it would be amazing!!  8-)
    bye sukkulento
  • »22.04.06 - 15:03
    Posts: 126 from 2003/2/17
    SATA cards are not (yet) supported by OF....
  • »23.04.06 - 03:38
    Sukkulento
    IT'S TIME TO UPGRADE THE PEG2 OF?  :-x
    No Comment!
    sukkulento
  • »23.04.06 - 08:05
    davidded
    Posts: 1 from 2006/4/23
    there might be an easy solution to the problem using the Raptor SATA disks (or any other SATA disk). You could try a SATA <-> ATA converter board. I found these for less than EUR 20 in stock.
    I also have a raptor and such a converter, but just a Pegasos I G3 600. So it would be a waste using this fast disk on a rather slow machine, but I might try out if it works.
    -Davidded.
  • »23.04.06 - 09:30
    nels664868
    Posts: 117 from 2003/12/28
    It could still work if you boot debian from an ide drive
    ie
    ide harddrive partition 3 /boot 100M-1G
    sata harddrive partition 1 swap
    2 / (root)
    this way OF can read the boot kernel and linux can read the sata card/drive
    you may have to rebuild the kernel to have the sata driver .
    nels
    Ask Dr. Stupid,
    Dear Dr. Stupid,
    Why do we have to go to school?
    That's a very good question. It's becuse your parents are
    ALIENS!!! When your at school they shed there human skins and
    breathe drier lint! hahahaha!
  • »23.04.06 - 11:31
    magnetic
    Posts: 2129 from 2003/3/1
    nels
    That is one demented penguin....
    mag
  • »25.04.06 - 21:03
    MarK
    Posts: 641 from 2004/1/25
    magnetic: no, that one is super cool penguin from super cool Red Dwarf series :)
    bye, MarK.
  • »26.04.06 - 05:55
    MarK
    anyway, is there ANY solution to connect more, than 4 ide/sata devices in pegasos supported by morphos?
    bye, MarK.
  • »26.04.06 - 05:59
    nels664868
    @ magnetic
    Mr flibble the crazy alter ego of rimmer from the Red Dwarf comedy/scifi show
    Ask Dr. Stupid,
    Dear Dr. Stupid,
  • »26.04.06 - 08:53
    analogkid
    Posts: 719 from 2004/11/3
    you could use an IDE-SCSI-Adapter with a SCSI-Controller.
  • »26.04.06 - 11:28
