Wifi PCI Prism II chipset board (802.11b)
    Tcheko
    Posts: 537 from 2003/2/25
    Anyone with a good experience with new wifi prism2 driver ?
    And most important : which board & manufacturer ?
    Thanks!
    /me wifing my home.
  • »28.06.05 - 14:11
    Robin
    Posts: 741 from 2003/2/24
    Netgear MA311 works :-) (I've not yet tested
    the new driver ... from the news it seemed the new
    is updated for OS4 only ;-) )
  • »28.06.05 - 16:34
    Posts: 236 from 2003/7/28
    I bought two of the cards from Amigakit.com. I tried it under MorphOS and while it works, it slows down after awhile and becomes too slow. Perhaps a MorphOS Developer could look at the source code and fix it.
    I think wireless (working properly) would be cool.
  • »29.06.05 - 00:16
    Crumb
    Posts: 732 from 2003/2/24
    does the prism2 driver work correctly on MorphOS with the latest OpenPCI libraries?
    I was planning to buy 3 cards for MOS use, but we are unsure
  • »16.03.06 - 09:26
    SoundSquare
    Posts: 1213 from 2004/12/1
    does MOS handle WPA security for wifi connections?
  • »16.03.06 - 16:23
    Robin
    I tried it a while back in my Peg2, and it worked with WEP.
    But I've not yet found a Prism2 card supporting WPA, so
    there is no need for support in the driver/OS ;-)
  • »16.03.06 - 17:36
    SoundSquare
    you're right Robin, i should have thought of it by myself.
    Prism2 is kinda obsolete, i'd love to see drivers for more recent wifi cards. it's always harder to find some older hardware, unless u wanna pay an absurd price at Amigakit (how the hell can they sell such expensive obsolete hardware).
  • »16.03.06 - 19:17
    Crumb
    @Robin:
    Have you noticed the problems described by HammerD? I'm planning to buy some wireless cards at amigakit, but as these cards are quite expensive I'd like to know if they work correctly. If the driver causes slowdown I'll get an ethernet access point.
  • »16.03.06 - 21:13
    Robin
    I have used it for two month or so. And MiamiDX had problems
    to renew it's dhcp-address ... but I cant remember having
    other problems.
    But I'd not tested with lots of data, so I cant say for sure.
  • »17.03.06 - 06:01
    ncafferkey
    Posts: 38 from 2006/1/6
    WPA is usually (always?) done in software. I think Prism II can support WPA. The closely related Hermes chipset certainly can. However, supporting WPA or newer cards would involve a lot of programming. With the Prism II, most of the work (for non-WPA operation) is done by the card's firmware.
  • »17.03.06 - 20:35
  • juergen
    Posts: 42 from 2005/2/2
    In order to use WPA, you first need a card firmware that's able to deal with TKIP encryption and several other WPA specialties.
    I think there is such a firmware for PRISM II, but I don't know for sure. For Hermes-1 chipset, a firmware V9.xx is required for WPA.
    Second, the driver must support WPA.
    Third, a supplicant is required that handles the WPA protocol (i.e. PTK/GTK handshake).
  • »17.03.06 - 22:16
    magnetic
    Posts: 2129 from 2003/3/1
    jurgen
    Good info...
    I would like to know if the prism driver works well as I may need to have a wireless card in the peg in the new studio... so please guys who have had it working can you provide a detailed performance report as well as probs discovered??
    tia
    magnetic
  • »18.03.06 - 22:50
    Sergio
    Posts: 90 from 2005/2/16
    My experience :
    I had troubles getting it to work, now it works OK but I generally don't leave my Peg turned on for long periods and I don't use much bandwith (I download from bittorrent and NGs on my other machine).
    The problem I found, and still haven't managed to fix is that if Miami is started too early it will block the prism driver. I have tried many things such as initializing the driver at beginning of user-startup and setting Miami's startpri very low, with no effect.
    Now I start Miami manually form my favourite toolbar prog.
    I haven't heard of anyone having the same problem, maybe it's because I use Scalos as WB?
    My config : Peg1 April2 MOS 1.4.5 Scalos 1.42 NetGear MA311
  • »20.03.06 - 08:19
    magnetic
    Sergio
    Thx for the report.. if there are other uses with experiences with the Prism wifi dirver plz report as well. tia
    magnetic
  • »20.03.06 - 08:37
