Posts: 315 from 2004/2/13
> Well, it worked "plug and play" like all USB Massstorage devices I ever tried have worked.
With Poseidon 2.x things were good but not perfect. Some USB hard disks did not work, and some pen drives did not work at all or worked asymmetrically (slow read, fast write). Poseidon 3 should have solved most or all these issues.
From your comment I deduce that you have used Poseidon 3 only, with no need for tweaking.
Thank you for the reply.
