Too much memory for MorphOS???
    winterhunter
    Posts: 204 from 2005/10/13
    Dear all,
    I had ordered a Peg II with 2 GB of RAM, and the retailer wrote to me on saturday to tell me that the machine didn't boot to MorphOS with that much memory (MorphOS showed a corrupt screen - it worked flawlessly under linux though).
    Has anyone experienced this kind of problem before? What could be the cause?
  • »31.10.05 - 11:24
    Posts: 1520 from 2003/2/24
    IIRC MorphOS supports max 1.2GB or 1.5GB atm.
  • »31.10.05 - 12:00
    Posts: 408 from 2004/7/15
    Simple. Remove one module and try again.
    iPod, iBook, iMac,... iRobot?
  • »31.10.05 - 12:21
    Jupp3
    Posts: 1193 from 2003/2/24
    I've heard that some gfx cards need to have small delay in startup-sequence, as they initialize too slowly.
    I'm not sure but I think the system should work with 2G of memory, the rest is just ignored.
  • »31.10.05 - 12:25
    Posts: 916 from 2004/1/24
    As it seems the 2GB shouldn't cause this problem. Try what Jupp3 suggested and add the command "wait 1" before "IPrefs" is loaded in the startup-sequence
  • »31.10.05 - 12:31
  • mk
    mk
    Posts: 72 from 2004/5/24
    AFAIK: Peg memory sector > 1,5 GB is mapped memory sector for Hardware.
    MorphOS work here with 1,5 GB Memory. 68k and PPC Programme can used this Memory full (here: Picview with 1,4 GB Preview Thumbnails in Memory, and another programms started from this!).
    BUT 2 Ram Modules (1024 + 512 MB) work be me (Peg2/G4) with rare random errors! (timing Memory /Smart Firmware init incorrect?)
    Big /extended Ram test with this 2 Modules (1,5 GB) is ok, but copy xx GB from one HD to another whit 2 Ram Modules get rare random, but errors. Programms work with rare random, but errors.
    With one RAM Module (1024 MB or 512 MB) same copy actions /programm execution its ok!
    [ Edited by mk on 2005/11/1 6:21 ]
  • »01.11.05 - 04:10
    Jupp3
    I got similar problem... With 2x256MB modules.
    Memory tests seemed to work, but there were random read&write errors (for example corruption in avi viewed in mplayer, when the file is just fine... If I rewind back, the error isn't there anymore)
    I just replaced one 256MB with similar (different brand) and it's worked just fine since then.
  • »08.01.06 - 09:47
