USB 2 Card for New Poseidon 3.2.
    matt3
    Posts: 782 from 2004/2/10
    What USB 2 card works with poseidon 3.2?
    Do you really get USB 2 speeds?
    If so I will backup my system to a usb 2 hard disk.
    Regards,
    Matt
  • »24.12.05 - 02:04
    Posts: 154 from 2003/4/22
    Any UHCI compatible card. Basicly, it means VIA PCI card.
    However, they only provide USB full/low speed aka USB 1.1.
    No you would requiere an appropriate EHCI driver which is not
    available ATM.
    Well, you still can but it will be very long ;-/.
    You can stil start up Linux and do the backup there.
    Bye
    Nico
    MorphOS Rulez !
  • »24.12.05 - 04:15
