MPC8641D Dual Core
    pegasosuser
    Posts: 138 from 2004/4/9
    I have read about upcoming MPC8641D Dual Core.
    I like this processor for the PEGASOSII and next PEGASOS systems.
    greetings Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »24.08.05 - 19:18
    minator
    Posts: 371 from 2003/3/28
    You should really read BBRV's last interview ;-)
  • »24.08.05 - 23:01
    poundsmack
    Posts: 1346 from 2003/6/7
    the dual core G4's make me feel all warm and fuzzy inside.....or mabey its all the beer :pint:
    either way  :-D
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »24.08.05 - 23:58
    mdma
    Posts: 85 from 2003/5/4
    As MorphOS has no support for SMP, I can't see why dual-core CPU's are anything t get excited about.
  • »25.08.05 - 01:07
    poundsmack
    doesnt have suport YET is the key....
  • »25.08.05 - 01:48
    jcmarcos
    Posts: 1178 from 2003/3/13
    poundsmack wrote:
    doesnt have SMP suport YET is the key....
    YES! You've found what is holding MorphOS 1.5 release! It will have both symmetric multiprocessing and distributed network processing!
    :-D
  • »25.08.05 - 05:24
    Posts: 2094 from 2003/6/4
    It is on radar since it's first announcement already. For PegII is doesn't make sense due to being a SoC solution which renders the need for a seperate northbridge void. The current PegII would brake the 8641(D) performance, but still the PegII will see a performance bost with the 7448.
  • »25.08.05 - 06:21
    tarbos
    Posts: 221 from 2003/4/19
    You can get the same package as a single core chip, too.
    In this case it does not even have to share the narrow internal FSB. :-)
  • »25.08.05 - 12:40
    Crumb
    Posts: 738 from 2003/2/24
    well, 8641D has a 666Mhz FSB, quite nice
  • »12.12.05 - 19:23
    Posts: 2732 from 2003/2/24
    @ Crumb
    The 8641 will be available in a single-core version as well AFAIK.
    Maybe a "power Efika"? ;-)
  • »12.12.05 - 21:26
    tarbos
    @Crumb:
    Still, it is a legacy bus that can only use half the
    combined bandwidth of the two memory controllers.
  • »13.12.05 - 18:12
