Radeon 8500 and MorphOS
    Schlonz
    Posts: 131 from 2004/4/16
    Hi all,
    does anybody of you know if overlay does now work with the Radeon 8500 and MorphOS?
    And are there any other limitations when using a 8500 compared to other Radeons?
  • »16.08.05 - 14:40
    realstar
    Posts: 298 from 2003/2/24
    Overlay seems to work fine on Radeon 8500 for me.
    I haven't seen any disadvantages either. I use a
    Radeon 7000 in a Peg2 and a Radeon 8500 in a
    Peg1 and I can't see much difference.
  • »16.08.05 - 15:23
    Schlonz
    So, if you try playing videos by Frogger or MPlayer, or if you try to play e.g. MAME with overlay, everything is fine?
    I ask because until MOS 1.4.2 there was no overlay support in MorphOS for Radeon 8500 afaik.
  • »16.08.05 - 19:13
    Druideck
    Posts: 82 from 2003/5/6
    I use Radeon 8500LE on Peg1, everything seems to work great,
    I use MPlayer and Frogger both with no problems.
    Druideck
  • »16.08.05 - 19:52
    pegasosuser
    Posts: 138 from 2004/4/9
    I have the RADEON8500-64Mb and working fine, and I buy now a RADEON9250-256Mb 128Bit.
    I sal testing the speed both card's and posting the results.
    greetings Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »17.08.05 - 05:59
    Piru
    Posts: 608 from 2003/2/24
    I'm very happy with my Club 3D Radeon 8500LE 64MB.
  • »17.08.05 - 06:56
    Schlonz
    Hi pegasosuser,
    I would not recommend to replace your 8500 by a 9250... it is slower for sure.
    You could search the internet for more information about this. I did find some comparison between the 8500 and the 9000PRO which showed that the 9000PRO is slower than the 8500, and both the 9200 and the 9250 are slower than the 9000PRO. So probably the best choice for MorphOS currently is the 8500.
  • »17.08.05 - 15:10
    pegasosuser
    I have now the RADEON9250-256Mb (128Bit) and working fine.
    I have the game BarkanoidII when I playing under RADEON8500-64Mb (64Bit) with dnetc running the game was slowly.
    and now with the RADEON9250 the game with dnetc in ful speed!
    greetings:-D Cor :-D van Londen.
  • »25.08.05 - 02:03
    Schlonz
    Hi everyone,
    I now own a Radeon 8500, and I am glad that the new 3D drivers were released the same day I installed the graphics card.
    All 2D operations are working great with it - including Overlay. A test with p96speed told me that the Radeon 8500 is quite a bit faster than my Voodoo4 I used before in most operations.
    And every single Warp3D game I own (e.g. all Hyperion games) work incredibly great with it. In fact, I can now play these games on 1024x768 faster than with my Voodoo4 on 640x480. Cool!
  • »27.08.05 - 20:22
    DedyAmigo
    Posts: 41 from 2003/7/19
    Hi folks,
    I have radeon 8500 le with 64 mb too, and it works on MOS
    fine (and works on my Peg I in Pegxlin too with resolution 1280x1024), and now with Peg II work fine in MOS, but when i start gentoo dvd live, physical resolution is allways 640x480, and if i want changed it
    in prefs is only res. 1024x768 and refresh freq. is 0.
    Please can you help me somebody? thx
    Dedy
    http://amigo.bodli.net
    Powerbook G4/1.67GHz, MOS 3.17 reg
    Asus Zenbook UX32VD, Xubuntu 20.04
  • »30.08.05 - 20:18
