RADEON 9250 256Mb
    pegasosuser
    Posts: 138 from 2004/4/9
    I will buy the RADEON 9250 256Mb, wiil this working with PegasosII and MorpOS?
    TNX!
    greetings Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »10.07.05 - 09:37
    hooligan
    Posts: 1948 from 2003/2/23
    Doubt it delivers anything over your current card. Don't bother.
  • »10.07.05 - 10:38
    Phantom
    Posts: 381 from 2004/9/7
    It will work with the new version of MorphOS (1.4.5)
  • »10.07.05 - 11:46
    Posts: 1926 from 2003/10/19
    I'm using one myself, but cant tell any diffrence over the 9200 I had before. So its not worth the update. From what I have read its a slower card then the 9200 as well. I got mine free so it was put in as a test since its the only computer I can try it in.
  • »10.07.05 - 15:39
    pegasosuser
    TNX Acill!
    Cor van Londen
  • »10.07.05 - 18:54
    tokai
    Posts: 1289 from 2003/2/25
    @acill: the 9250 is for sure faster than a 9200 (i think ;) ). Only 8500 could be slightly faster. But considering 9250 has better availability these days than a 8500 its not a bad choice.
    But it's true it's not worth upgrading a 8500 to a 9200 or 9250.
    But If someone needs a new card for whatever reason I would go for a 9250 instead a 9200. :-)
  • »10.07.05 - 18:58
    pegasosuser
    hello Tokai,
    I woul buy the RADEON 9250 also for the big memory is the 8500 faster then the 9250?
  • »10.07.05 - 21:23
    pegasosuser
    I have now buyed the RADEON 9250 256Mb 128Bit this card have 128Bit memory thus this must faster then the RADEON 8500 with 64Mb and 64Bit memory?
    :pint:
    [ Edited by pegasosuser on 2005/8/7 10:05 ]
  • »07.08.05 - 09:04
