Posts: 118 from 2003/2/24
Hi everyone !
About one year and a half ago, I had a peg2, with a SB Live that worked great under MOL with the alsa drivers, even with games such as diablo 2.
Now, I have a new peg2 and a new SB Live (that works perfectly under MOS), but now, under MOL, the sound doesn't work properly. (2.6.11) - sb live and alsa drivers.
Here is what happens for instance if I launch starcraft :
- at the first launch it usually works perfectly
- I play one level then the sound suddenly ceases to work, and the mouse pointer (well, MOL) freezes one second, then works again, and so on, until I quit any app that makes sound... I have to restart MOL to get a little sound again.
--> this is something I experienced, I think, last year, with the onboard sound and ALSA.
I didn't give up and tried the onboard sound chip with the alsa drivers, as some friends reported it to work. However, if I manage to get sound with the alsa driver with, let say, xmms, I get none with MacOnLinux that fails to use the device and falls back to the OSS driver. I also get an error message in my dmesg, I can copy/paste it when I get back home. With the OSS driver it doesn't work at all. I just get one bit of sound once in a while - but MOL doesn't freeze.
What is stranger, so with the onboard sound + alsa, is that, each time I reboot, alsamixer tells me it's using the sb live... Though meanwhile I had launched & configured the via chipset with alsaconf. I checked scripts etc, it "seems" normal...
Well, I'm kinda lost... Any idea ?
I would really prefer using the sb live as I have the feeling its sound is much better. (I use it on hifi system)
Last year I remember I had to disable (in /etc/modules) some OSS drivers to make alsa work properly. I tried to do so with this new installation, but it makes no difference, they seem to get loaded anyway - much more automatic stuff and much longer booting time than my former debian install, one year ago.
Thanks for listening :)
Off-topic : did anyone find a solution to make >=512MB fat formatted SD cards work with poseidon ? I have several but none works ATM though other stuff work well with the very same card reader :)
[ Edited by mahen on 2005/8/3 14:44 ]
xmpp:mahen on jabber.fr
