Multiple Gfx card setup
    Posts: 278 from 2003/3/4
    On my A4000 I was used to have multiple screens at the same time for different applications (I had CV64 + CV64 3D + PIC 4 + RetinaZ3+ Permedia 2).
    Since tonight my Pegasos 2 is running 3 gfx cards. I thought it may interest some people to know about this working gfx cards combination:
    - Voodoo 5500 AGP -> IRC, 3D games , etc
    - Voodoo 3000 PCI -> Browsers, Opus etc
    - Radeon 9000 PCI -> Ambient screen
    [ Edited by cdfr on 2005/7/5 21:54 ]
  • »06.07.05 - 02:52
    Mario
    Posts: 46 from 2003/4/27
    Nice!
    Just some questions:
    - did you notice whether the screen is still centered or "shifted" to the left/right when you change gfxcard ?
    - is it worth having two voodoo cards? Wouldn't it be easier using the same 5500 for browsers, opus etc? Why do you prefer voodoo 3000 instead?
    - did you try linux install with your radeon pci?
    - do you use screen promoters like newmode or modepro to open games on the right screens?
  • »06.07.05 - 06:49
    I have a setup with 3 monitors. I switch between screens with the screen gadget or shortcut. I have no problem.
    The point was to use all my monitors at the same time to benefit from having much more display space available. The applications example I gave was just an example. I can open each app on what screen I want anytime in function of what is in use.
    I prefer the Voodoo 3000 because the output is more crisp.
    Not yet. I will certainly later.
    All the games I have are RTG friendly.
  • »06.07.05 - 12:52
    magnetic
    Posts: 2129 from 2003/3/1
    Mario
    Linux works fine with radeon pci cards. I used to have just that very radeon 9000 pro pci and used it with Debian, YDL, and Gentoo linux.
    Additionally, I had it configured for Dual shared Display!
    :-D
    magnetic
  • »08.07.05 - 16:03
