Pegasos I memory guidelines . . .
    klesterjr
    Posts: 196 from 2005/4/1
    I've read the list of working verses non-working memory located HERE -- but I'm wondering if someone could provide some "general" guidelines for memory that SHOULD work (registered, non-registered, CL2, CL3, etc.).
    I've got a 256 meg stick laying round that I plan to try, but I don't have high hopes that it'll work.
  • »17.06.05 - 09:47
    Sergio
    Posts: 91 from 2005/2/16
    Go for ECC Reg CL3 if you can, that's what I did and it just worked.
  • »17.06.05 - 20:19
    klesterjr
    @Sergio
    Thanks -- that was kind of a "pattern" I was seeing with the sticks that worked.
  • »17.06.05 - 20:59
    judas
    Posts: 175 from 2005/1/14
    Can anyone tell me a theory, why my samsung -322 is detected as the doubled size.
    Peg1 detects 256, but the stick just has 128.
    bye
  • »18.06.05 - 05:17
    Posts: 2732 from 2003/2/24
    klesterjr wrote:
    @Sergio
    If the one you have at hand does not work, you could always check this out (at the bottom of the page):
    http://www.ggsdata.se/Amigaone/en.html
  • »18.06.05 - 05:24
    ironfist
    Posts: 254 from 2004/4/22
    Can you use 256 MB on it?
    Sounds to me like some kind of memory shortage where
    they took a 256 MB, rebranded it and maybe did
    something so Windows only sees 128 MB..
    I've seen this on HDDs - 2.1 GB harddrive branded as 1.6 GB
    and had a function that prevented formatting more..
  • »18.06.05 - 05:26
