Posts: 349 from 2003/10/12
1., Are you sure that your memory module is correct & bug-free?
2., What Firmware version do you have?
3., What kernel version are you running? (2.4 and early 2.6.x kernels are known to corrupt the memory, due to conflicts with the IDE controller mappings, when using more than 256MB esp. with older Firmwares).
Try use mem=256M argument when booting and see if it's everything ok.
