RAM, CPU, VGA heat issues
    Leon
    Posts: 93 from 2003/11/28
    Hello,
    I wonder if you have any RAM related problems, such as overheating and so on. Did you at some point recognize that the RAMs are getting very hot? Is this possible on Pegasos2 with 266mhz bus speed?
    What about the CPU? I am cooling the CPU with a Titan branded VGA Cooler. It is very quiet.
    And there is the VGA card. Is there a chance that the card gets very hot for some reason?
    I think that all these three components have absolutely no reason to get overheated, assuming the CPU is actively cooled. Am I right?
    [ Edited by Leon on 2008/5/2 14:29 ]
    Proud owner of:
    Efika
    ABIT ATI 9200SE AGP 128MB
    40GB Samsung Hard Drive 5400rpm
    PowerMac 3.1 G4 350Mhz "Sawtooth" AGP
  • »20.05.05 - 17:07
    magnetic
    Posts: 2129 from 2003/3/1
    Hi Leon
    If you have a voodooo card it does get hot yes.. as do other radeons sometimes.
    The ram shouldnt be THAT hot, but does get hot like any other chip... but if it gets REAL hot it may have a problem.
    Magnetic
  • »20.05.05 - 17:22
