Radeon 7000 & MOS 1.4.5
    shedroveme2
    Posts: 26 from 2005/5/9
    Hi can anybody please post there expirences of running MOS.1.4.5 with a Radeon 7000, i think there maybe a problem with my 7000 and the new radeon driver, any help would be apreciated.
    Thanks
  • »12.05.05 - 10:54
    ossian1961
    Posts: 123 from 2004/7/31
    I use Radeon 7000 with 1.4.5 with no problem. Have you updated Mos or installed 1.4.5 alone?
  • »12.05.05 - 11:31
    shedroveme2
    can't even get that far, after Quark starts my screen goes blank and monitor goes into powersave, 1.4.3 worked fine tho???
  • »12.05.05 - 11:39
    ossian1961
    Are you sure about the monitor configuration? I have an lcd hp and the HF - VF values declared were wrong but the Linux auto config shown me the correct values that I used in Mos and now all it's ok.
    HP values (HF: 30-63, VF: 50-76) Bandwidth 76
    Linux gives (HF: 28-50, VF: 43-75) Bandwith 75
  • »12.05.05 - 15:03
    The_Killer
    Posts: 3 from 2004/5/17
    I have the same problem here.
    I can't install MorphOS 1.4.5..... plz. hlp...
    The same problem is with other monitor !
    The_Killer
  • »14.05.05 - 15:53
    Leon
    Posts: 93 from 2003/11/28
    Does this happen after you install MOS or when booting the CD?
    Maybe you can boot the CD and edit the monitor value for CybergraphX in ENVARC to a lower value.
    Proud owner of:
    Efika
    ABIT ATI 9200SE AGP 128MB
    40GB Samsung Hard Drive 5400rpm
    PowerMac 3.1 G4 350Mhz "Sawtooth" AGP
  • »15.05.05 - 16:13
    The_Killer
    @Leon
    The Problem is when i boot from the CD.... :-x
    The_Killer
  • »15.05.05 - 17:35
    shedroveme2
    having done a manual install of 1.4.5 from a 1.4.3 cd, i have found that if you replace the radeon driver, with a different version it work's perfectly... looks to be a problem with the new radeon driver
  • »16.05.05 - 13:36
    magnetic
    Posts: 2129 from 2003/3/1
    Hi guys
    fyi.. i installed 1.4.5 from cd perfectly and it runs nicely on my Radeon 7500..
    magnetic
  • »17.05.05 - 23:23
    analogkid
    Posts: 719 from 2004/11/3
    works here without probs.
    Peg1, Radeon 7000, MOS 1.4.5
  • »18.05.05 - 04:25
