What is the Pegasos 2.5? 3?
    Bodie_CI5
    Posts: 99 from 2004/6/19
    Targhan wrote:
    @Bodie_C15
    If by some strange alignment in the stars occurs with a fullmoon and a port appears
    Well things must be in alignment then! 8-)
    (*Disclaimer: I know nothing of zodiacs and astrology and/or astronomy)
    An ode to Wayne Miller:
    "Oooooh yeahh!"
  • »09.05.05 - 06:49
    Neko
    Posts: 301 from 2003/2/24
    @Bodie;
    It doesn't hurt but it won't get you anywhere. Don't you think everybody has already asked?
    @petition-idiots;
    That would do more damage than good.
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »09.05.05 - 09:26
    Posts: 1932 from 2003/10/19
    [quote]
    Senex wrote:
    [quote]If such petition would be organized by the staff and users of AW.net it might have some impact ... [/quote]
    [quote] How? You're forgetting that the eternal problem are Amiga Inc. And regarding OS4 for the Pegasos, Acill has been even ready to pay Hyperion's porting costs from his own pocket - but I'm very certain he still didn't get any reply from AI... [/quote]
    You would be correct, I havent got a single reply and its been jst about two weeks now. I know it was read because i put a tracker on it. To bad they wont just release it without them giving the okay. The only one making money on it is them, I guess Amiga Inc. is doing so well now that they dont need to answer emails from people wanting to get products out the door that will directly bring in money for them. Its must be nice for them. :roll:
  • »09.05.05 - 09:51
    Eric_S
    Posts: 1 from 2005/5/9
    Neko wrote:
    2) License for OS4 has been specifically designed to protect the AmigaOne by charging hardware manufacturers regardless of the OS running on the board, and/or restricting it to high-end resellers who have "a storefront". They know fullwell there isn't an Amiga or Pegasos reseller on the planet with a storefront.
    If that's the problem (and there isn't a well defined legal defenition that says otherwhise) then I don't see how you couldn't "cheat" a bit with the help of a willing reseller. A store front is simply the "facade of a store" or "A room or set of rooms facing the street on the ground floor of a commercial building, typically used as a store." All you need is a room that's facing a street som day, a couple of minutes of the year where you take orders from. ;-)
    @Acill
    Again, cheat a bit (if you don't get a reply).
    Talk to someone that you know has got a contact with Garry Hare, DaveyD for example, and get him to forward your mesage. At the same time send Garry/(whoever you are wanting a reply from) another message yourselfe.Make shure that you get (for example) DaveyD to say that you have sent Garry/*** a letter before and is sending Garry/*** one now, and that you meerly are using this option as you think that perhaps the firewall has been overly strict. This allso saves the whole "only unserious people make others send mails for them" deal from ever taking place.
    If you/or the other sender still don't get a reply, then we do have an interesting situation on or hands. Aspecially if the ACK comes through with their boards, and there is a large portion of the users that want to see OS4 on the Peg 2 and future Pegs.
    [ Edited by Eric_S on 2005/5/9 12:35 ]
  • »09.05.05 - 15:34
