Posts: 2057 from 2003/6/4
I tried a cheap Trekstore usb flash player and it worked instantly. They are quite cheap (at least in
Germany, about 40 EURs for the 256 Mb model) and it accecpts normal
AAA-cells (make sure to use NiMH cells only to protect your wallet and
the ecology!).
Also the IRiver HP-120 is reported to work with Poseidon. That is
one not really cheap (comparable with iPods), but seems to be worth
it's price. It is said to be the most audiophil MP3 player out there
(can record digital and analog in full quality, has a strong line out
(no weak bass, but a linear frequency curve) and replays ogg also).
