Help Installing AmithlonTV
    magnetic
    Posts: 2129 from 2003/3/1
    Hello
    I just purchased a nice BT878 Happauge WINTV Pci card for my Peg. I also downloaded the Amithlon TV software. I installed the program and it launches. I get a picture but its really screwed up looking, is there any special settings I need? Any help is appreciated.
    Also has anyone tried that other capture software for peg?
    magnetic
    [ Edited by magnetic on 2005/3/17 1:23 ]
  • »16.03.05 - 20:09
    Posts: 1086 from 2003/3/24
    Why you didn't use Visionary?
  • »16.03.05 - 20:18
    magnetic
    Hi Player
    Thanks for the response.. Do you have a link to Visionary? I tried vgr.com but couldnt connect..
    BTW I fixed the prob with Amithlon tv - the prog defaulted to PAL :-)
    Anyone who has used apps/programs with a tv card please post results here.
    magnetic
  • »16.03.05 - 20:30
    You got Mail! :-)
  • »16.03.05 - 20:42
    magnetic
    Player
    Thanks alot :-D You are the man!
    However... :-(
    Trying to launch:
    1. The Outstanding Looking Icon "Visionary" I get a requestor that says "can't open version 0 of amigaguide library"
    2. Try to lauch "oldVisionary" icon I get
    "NO Mimetype for Mos2:Tools/Visionary"
    3. From "Visionary 0.18" launch I get:(yet) unsupported Hauppauge WinTV model 44801 tunercode 0xa revision C310
    no skin !
    4. From "Visonary.021" I get same error as 3
    5 and "Visonaryxxx" give same error
    Are we missing something?
    tia
    magnetic
  • »16.03.05 - 21:06
    Yeah i know that i am the man ;-)
    no all you need shoud be in the Dir, maybe you Card won't work with Visionary i had a Hauppauge WinTV that refuse to work, it had a different Revision that i have now.
  • »16.03.05 - 22:13
    Posts: 20 from 2004/2/26
    btr_8x8 v0.06 can work with Hauppauge WinTV 44914 now! :-)
    If it cant work with WinTV 44801 - just email me  ;-)
    Autor of the BTR_8x8 - Video Capture program for MOS/QNX4/Windows.
  • »19.04.05 - 16:35
