Posts: 142 from 2003/12/27
I have a 160 GB Samsung, so the size of Disk should not matter. You made a new Partition, then reebooted and formated the Drive - right?
Are you sure the Drive is set to "Master" and is on the first ide channel? (Reading your Post points to it - but better make sure it is
Maybe you try to install from CD first and look how this works.
There was a "bug" in some Firmware Revisions that let certain drives only show up after a Reset but not after a cold restart.
That's all i can think of in the first line...
Bye
Donar
[ Edited by Donar on 2005/3/3 7:10 ]
