OpenPCI 2.0
    Posts: 1932 from 2003/10/19
    Was a 2.0 release done? If so was one done for MorphOS? I've seena few
    things mentioned about it but havent ever seen the releasse.
  • »05.01.05 - 14:06
    Posts: 1090 from 2004/9/23
    There is a OpenPCI V2.0 version for MorphOS which contains several strongly required functions.
    Unfortunatly, these functions aren't working and any driver which is using them won't work, too.
    Guido Mersmann
  • »05.01.05 - 15:28
    Posts: 20 from 2004/2/26
    OpenPCI v1.2 didn't return the memory, after PCI_FREEDMA_MEM(). This bug very easy to detect - just run many times 'openpciinfo'.
    Is this bug still present in v2.0?
    Autor of the BTR_8x8 - Video Capture program for MOS/QNX4/Windows.
  • »05.01.05 - 21:38
    I don't know! I just made a few tests on Amithlon with the latest version and it's working perfect there.
    Guido Mersmann
  • »05.01.05 - 21:55
    Where I can download OpenPCI > v1.2 ?
  • »06.01.05 - 21:50
    GK_LKA
    Posts: 481 from 2004/3/28
    http://www.chez.com/titan/OpenPciUK.html
    [ GK / LKA Team ]
  • »07.01.05 - 19:14
    This page contain just v1.2:
    http://www.chez.com/titan/OpenPciLib1.2.lha
  • »07.01.05 - 23:09
    Tcheko
    Posts: 543 from 2003/2/25
    Hello,
    Standard OpenPCI for MOS is 2.0.
    To check version : open a shell, type version openpci.library.
    If everything is ok it will give 2.0.
    Regards.
  • »08.01.05 - 15:31
    My version is 1.1 and I got the below mentioned 1.2 so where is the 2.0 at?
  • »08.01.05 - 18:15
    I have v1.1 of openpci.library on my CD with MOS.
    And I was update it to the v1.2 via aforesaid link.
  • »08.01.05 - 21:50
    OpenPCI V2.0 is not available for the public.
    There is no need to use it, because it's new features aren't working correct.
    I don't know if they ever get fixed, because the author told me to quit amiga programming around April last year, when delivering the first beta version. Didm't hear anything since then.
    Guido Mersmann
  • »08.01.05 - 23:10
    Posts: 13 from 2003/5/3
    @ geit
    Maybe i'm too optimistic but can't you ask him to take over the
    development of OpenPCI? you are a very skilled programmer! :)
    Or what about using IOUSB 2.2 for drivers from Felix Schwarz? Or is
    this something complete different?
    [ Edited by SOL-Invictus on 2005/1/9 15:44 ]
  • »09.01.05 - 06:43
    cecilia
    Posts: 459 from 2003/8/30
    so what does this library do?
    and what does 2.0 do that's an improvement?
  • »09.01.05 - 22:25
  • HAK
    Posts: 225 from 2003/2/24
    @ geit,
    So, does this mean there will be no ArrakAttack in the foreseeable future for MOS?
    I tried it some weeks ago, but as it asked for OpenPCI 2.0 and I never got hold of it I simply forgot about it.
    Bye HAK
  • »10.01.05 - 05:33
    Yes, but there will be an other option.
    It requires some of the function. When I released the stuff I expected the functions to be fixed, soon.
    With 2.0 it's finally possible to allocate pci cards, so no second driver is poking the same hardware. My driver grabs any USB controller it find and that would collide with the MorphOS version. There is also a missing memory address converting function implemented, which is very important.
    Guido Mersmann
  • »10.01.05 - 22:56
    magnetic
    Posts: 2129 from 2003/3/1
    Guido
    Thanks for posting on this site and thank you for ALL of your development work.
    Will there be USB 2 support for MOS in the near future?
    tia
    magnetic
  • »10.01.05 - 23:20
    cecilia
    ok, I understand that's out but is there a list of PCI cards that will work?
    I've read that for a PCI USB card it should be "based on VIA 6202 chip".
    not being a hardware person i'm not sure exactly what that means but i wrote it down anyway.  :-D
    is that all i really need to know?
    and let me say thank you to all programmers of these things.
  • »11.01.05 - 15:08
    "Via" Chips are using UHCI/EHCI combinations. Since there is an UHCI driver for MorphOS (e.g. Used for the main board) cards with those chips are working out of the box, but only with 1:1 speed.
    "NEC" Chips are using OHCI/EHCI controller combinations. Currently there is no OHCI and no EHCI driver, so these cards aren't working.
    Guido Mersmann
  • »11.01.05 - 20:43
    Donar
    Posts: 142 from 2003/12/27
    Maybe you all should have a look at:
    http://www.chez.com/titan/DevPCI.html
    The first after Download lower / right part is the OpenPCI 2.0
    Credits goes to DJBase found that at the Pegasosforum  :-D
    Bye
  • »18.02.05 - 17:42
    works well, copy openpci.library.elf to mossys:libs an remove the .elf
    part. It locked up on me if I didnt do that
  • »18.02.05 - 21:49
